Transmission replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SRK, Jul 26, 2018.
  1. SRK
    SRK New Member
    Gainesville, Florida
    a number of warning lights appeared, would not start nor move out of neutral. Garage man said following codes were given: P0AA6-612 LODGED IN COMPUTER MEMORY INDICATING "SHORT TO GROUND" AND GENERATOR FAULT CODES. WE RECOMMEND TRANSMISSION REPLACEMENT AND CONTINUING DIAGNOSIS IF NEEDED.
    ($5,OOO)
    What am I missing here? Had it towed home and it started right up and drove O.K.
  2. benagi
    benagi Active Member
    525
    280
    Utah
    Something like that happen on my Prius v a year ago. It was just a dieing 12 volt battery. Replace the battery and haven’t had a problem since.
  3. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Sure, if that was the code he got, it means the transmission has to be replaced.
    In my opinion, you don't have to buy a new one. You can get one from a salvage yard, if you can, replace it yourself.
    Be sure you got a Toyota WS fluid in the new transaxle.
    Dxta
  4. SRK
    SRK New Member
    Thanks, I will have it checked out.
    #4 SRK, Jul 27, 2018
  5. SRK
    SRK New Member
    Thanks for the reply. I guess I just was not aware that the electrical converter component was integral with the trans-axle. I am not capable of or equipped to do the replacement part. I will attempt to find some that can help or do the job for me.
    #5 SRK, Jul 27, 2018
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    P0AA6-612 is High Voltage Fault detected in the transaxle or the Inverter. Those are 2 separate devices. There is also the 526 sub code which is a high voltage fault from the Hybrid battery. The car is detecting leaking high volatge. In the trans its from a blown motor winding. if the battery is from a craked and leaking battery module leaking electrolyte and conducting to ground.
    You have a very old car with probably very high miles. be aware if you go through the trouble and expense of replacing the transaxle the hybrid battery failure is soon to follow.
    You have alot of reading to do.
    use the search forums button up top and search:
    hybrid battery
    so you can see what hundreds of people are going through right now with there battery's.
    Dxta likes this.
  7. SRK
    SRK New Member
    Thanks for all the replies! Was able to get #1,000 on a trade. 2017 Prius three.
  8. jerrymildred
    jerrymildred Senior Member
    11,491
    14,102
    Tampa, FL
    Cool!!! Enjoy the new buggy.
  9. Jordanhiggins2002
    94
    39
    Socal
