transmission shifter motor wiring?
Discussion in 'Gen 3 Prius Technical Discussion' started by ferraribuyer, Oct 24, 2012.
  1. ferraribuyer
    ferraribuyer Junior Member
    30
    MN
    My 2012 prius i bought crashed in front and the plug broke at the connection point. I need a picture of the plug in connector so I can rewire it properly. right now the car wont go into park because of this issue. Thanks
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    You probably need to go to the online Toyota TIS (technical information system), pay the $15 for a two day session and go through the electrical diagrams to make sure you get the correct connector.
  3. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Tran shifter motor in Prius? Without exact plug position or picture (better) we could not help you. Jdc5 is right about TIS subscription.
  4. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    See if these help...
    Chazz8 likes this.
  5. ferraribuyer
    30
    MN
    Thanks guys. I actually went to look at another prius to see the order and color of wires. I replaced the shifter park controller and now can get the car in park and N but thats it. I cant get it into D or R or even start. More problems ahead I guess.
  6. ferraribuyer
    30
    MN
    I didnt replace the shifter in the car but the part that goes on the front of the transmission that senses the position. Im really not sure what it does.
