Transmission ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jerry Liebler, Nov 3, 2014.
  1. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    Does anyone know if the plug in uses the same "transmission" as the hatchback and if different what are the differences?
    49,409
    same, with a larger motor. does that make it different?:confused:
  3. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    I assume you are saying the power rating of MG2 is higher, is it physically a different size or simply rated differently?
    Are there any gear ratio differences? Something I read suggested that the "speed reduction" planetary had a different ratio.
  4. mrbigh
    3,686
    699
    Long Island, NY
    I think they are model specific. Why do you want to downgrade to a lesser component? or upgrade to a better component
    that can not be usable to it fullest capabilities?
  5. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    I'm not planning any swaps. I would like to understand all the differences out of simple curiosity.
  6. markabele
    5,084
    1,782
    Nebraska
    Same exact car in almost every way as the regular Gen3 with just a bigger battery. I don't believe either of the MG's differ in size compared to the Gen3, but I could be wrong on that.
  7. bisco
    49,409
    that's about as much as i know too.:cool:
