TRD exhaust install
Discussion in 'Prius c Accessories and Modifications' started by loklok1, Apr 4, 2014.
  1. loklok1
    loklok1 Junior Member
    47
    It arrived after more than 2 months wait and finally had time to put it on. It was direct bolt on and perfect fitment. Sorry for the poor picture quality, just though I share how it looks on a C.
    Xterra72 and deckbuild like this.
  2. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Other then the change in sound any other improvement?
  3. loklok1
    47
    nope even the sound didn't change, it is as quiet as stock.
  4. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    It makes your wallet much lighter, so it incrementally improves mpg. ;)
    SCH-I535
    Seal2, xpcman and ztanos like this.
  5. loklok1
    47
    i guess so
  6. priusCpilot
    663
    210
    LA
    I'm surprised the sound didn't change a little? I heard a vid and it was nicer then stock but quite which I like.
    It would be nice if it made even 1HP more.
  7. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    It will probably break in after a few hundred miles and get slightly louder.
  8. B2FiNiTY
    979
    227
    After break in, I'm sure it will sound a little bit louder.
  9. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    So then what WAS the point ??
    Montgomery likes this.
  10. B2FiNiTY
    979
    227
    Looks better?
  11. The Mouth
    The Mouth Junior Member
    91
    24
    Simi Valley
    Cost? I'm debating on either doing something similar or just cutting the tip off higher up so it is not visible. Not sure what???Definitely don't want to any sound if I add a new exhaust or tip.
  12. Easy Rider
    982
    210
    N. Central Florida
    Cost ?? What ??
    Taking off a perfectly good stock exhaust system and replacing it with a different one.......that sounds about the same, just so you can have two chrome extensions sticking out the back instead of one ??
    I'd still like to hear from the guy that did it to find out what his thinking was.
  13. priusCpilot
    663
    210
    LA
    This is close to $1g or less shipped I believe?
    Here is how its sounds.
    I like it personally. This is TRD not some aftermarket system.I would say there should be some minor improvement but??
    I did 0-60 10.2s stock on SG2. Wounder if I can get less with the TRD exhaust?
  14. loklok1
    47
    actually it sound the same when i was on eco mode. after i turned off eco mode it sound different.
  15. priusCpilot
    663
    210
    LA
    I guess due to ECU changing the throttle position?
  16. priusCpilot
    663
    210
    LA
    I wounder how much lighter this muffler is over stock?
  17. xliderider
    8,140
    3,278
    Honolulu, HI
    It's most likely heavier than stock.
    SCH-I535
  18. loklok1
    47
    both weight about the same imo. i didn't notice one heavier than the other when i lift them up.
  19. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
    Found this on eBay about 2 years ago. Came off of a Turbo Yaris Vitz In Malaysia. Very rare. Sounds awesome. Increased performance.
  20. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Can you record a video?
