TRD kit
Discussion in 'Gen 3 Prius Main Forum' started by douglasjre, Oct 12, 2023.
  1. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Does this car use the same shocks and struts as a Corolla? Perhaps there's a cruella TRD with upgraded stiffer shocks that we can order?
  2. Tombukt2
    Tombukt2 Senior Member
    13,856
    2,516
    Durham NC
    If the Corollas that you're looking at has the aluminum front hub then they will probably fit may need a spring rate adjustment or coilover set to make that adjustment a set of coilovers from an AE11 1 Will bolt up to the car and they are the right height I can provide pictures The only thing that will not bolt up or slip together is where the aluminum hub slips into the double ears on the strut and the two 19 mm bolts go in You can't spread the Corolla far enough the coilovers because they're made very tightly and there's just not that much room as the later model Corollas get the aluminum front hub that would probably make everything go even the top plates go in the holes and bolt up I have them sitting right here they're adjustable rebound and compression gas adjust type shocks inside of coilover assemblies these coils are about 4 in round and I can pick from thousands of them they're laying right here on the floor of course I guess I could take a set of hubs and have that mounting point mill down I don't know what 110 thou and it would fit
