TRD Lowering Springs?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 818prius, May 9, 2012.
  1. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Totally agree:rockon:.
  2. justana
    justana Junior Member
    60
    Thanks. I was gonna installed eibach or TRD but its not drop enough, tein got issue with rubbing for my set (too low), so i got it in between....;)
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If ur looking for a de decent drop the don't go with TRD
  4. rickelchilango
    rickelchilango Junior Member
    32
    I did some research before deciding to go with the TRD springs myself.. Here's what I found..
    Tein HTech Springs - 1.4" drop (front) and 1.5" drop (rear)
    TRD Springs - 1.1" drop (front) and 1.3" drop (rear)
    Eibach - 1.2" drop (front) and 0.8" drop (rear)
    I went with 18" wheels, so the Tein HTech springs were a little too much (I thought), but the Eibach's were no enough.. So, went with the TRD instead.. I also wanted to stay away from rubbing, and figured I used Toyota parts as well..
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Rickel, would you mind adding the spring rates in your post for future reference? The drop information is good but the spring rates will help people determine how tight or cushy a spring is.
  6. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Why don't you guys just cut your stock springs?
    Jk don't.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    :pound::pound:
    That's funny.
  8. justana
    60
    pictures please...
  9. d2mini
    d2mini Active Member
    519
    106
    Houston
    Look at the difference in front to rear drop between the TRD and the Eibachs. :eek:
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I found that rather odd as well. If that is really the case then it really strengthens my appreciation for Eibach springs. I don't like the "level" look and the Eibachs seem to provide a little more of a rake (front end lower than the rear). Once I finally get around to it those are the springs I'll likely get.
  11. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    I measured all four corners before and after my Eibachs. It is actually 1.0" in the front and 1.0" in the rear. I am sure there is some percentage of tolerance in the springs and car parameters. The balance front to rear is spot on...but cannot go any lower or it will rub (at least with my rims and tires). And I would not want to go up on the spring rate...quite stiff as it is.
  12. d2mini
    519
    106
    Houston
    I've got close to 1000 miles on my eibachs now and I have two of the exact same cars in the garage, the other is completely stock. My fronts are 1.25" lower in the front and my rears are 1.5" lower. But the fender gap is exactly the same. I do have a little bit more weight on the back with the curt hitch and bike rack, so i suspect that may be resulting in a slightly larger drop in back. But for sure it's no more than .25".
  13. nivla
    nivla New Member
    just picked up a set can't wait to have them installed!:cheer2:
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I've asked this question before but it never really gets answered........why dont more people go with H&R springs?
  15. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Probably because it doesn't seem to get advertised as much.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    H&R shows a spec drop of 1.3" front & 1.2" rear
    Maybe that explains why some have asked why mine looks lower compared to Eibachs.
  17. SoCalBPrius
    563
    118
    SoCal
    I had this(H&R) on order & nearly bought it but canceled last minute after I saw couple members here on Eibachs. Maybe, if I had seen some prius examples on H&R's I might have gone through with it as it's hard being the guinea pig:D.
  18. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    how are the tanabe lowering springs ?
  19. eseymour72
    eseymour72 Junior Member
    46
    Lincoln City, OR
    For those that are interested, here is some infor on spring rates OEM vs. Eibach.
    PRO-KIT—TOYOTA PRIUS 2010-11 DATA:
    TECHNICAL INFORMATION
    FRONT:
    OE rate: 21 N/mm (120 lbs/in)
    PK rate: 29 N/mm (165 lbs/in)
    Tubing: None
    Bump-stop:
    New Eibach Springs bumpstop
    Damper: New OE
    OE wheel center to fender: 381mm (15.0in)
    PK wheel center to fender: 351mm (13.8in)
    Front Alignment:
    OE Camber =
    -0.22 +/-0.75 deg
    OE Caster = 6.07 +/-0.75 deg
    OE Toe = 0.20 +/-0.20 deg
    PK Camber = -0.2 +/-0.5 deg
    PK Caster = 6.2 +/-0.75 deg
    PK Toe = 0.2 +/-1mm
    Pro-Kit can be aligned to OE specifications.
    Approximate installation time: 1.0 hr
    REAR:
    OE rate: 27 N/mm (154 lbs/in)
    PK rate: Progressive 25-34 N/mm (143-194 lbs/in)
    Tubing: None
    Bump-stop: New OE
    Damper: New OE
    OE wheel center to fender: 369mm (14.5in)
    PK wheel center to fender: 348mm (13.7in)
    Rear Alignment:
    OE Camber = -1.5 +/-0.5 deg
    OE Toe = 0.33 +/- 0.3 deg
    PK Camber = -1.4 +/-0.5 deg
    PK Toe = 0.24 +/- 0.3 deg
    Download This Newsletter in PDF Format
  20. eseymour72
    46
    Lincoln City, OR
    Here is Tein H Tech info:
    Tein H Tech Lowering Springs Kit Toyota Prius 2010-2012
    SKU:TEN-SKQ08-G1B00 (30989)MSRP:$215.00
    Tein is a well-known name when it comes to spring and coilover damper kit. Tein products are made in Japan with high-grade material for performance and quality.
    Tein H Tech lowering spring provides approximately between 1.0 to 1.9 inch drop to achieve a balance between aggressive styling and comfortable ride experience. Check the detail specifications of each Tein H Tech spring set for your car for the exact height drop measurement (included below).
    Most Tein H Tech spring sets feature rubber spring protector tube to dampen noise level. Tein H Tech springs are first coated with zinc phosphate, a rust-proof material. The H Tech springs are then finished with a long-lasting gold powder paint. In addition, each Tein H Tech spring is made using a new material called Vanadium (SAE9254V), a strong, lightweight material that retain more spring stroke for optimal quality.
    Tein spring manufacturing is a multi-step process involving:
    1. Cold-coiling to create the spring
    2. Low temperature tempering treatment to eliminate residual stress
    3. End-face grinding according to the form of each car application
    4. Double shot peening to the spring surface to increase spring life
    5. Setting at elevated temperature to minimize loss of spring load
    6. Coating treatment to prevent rust.
    Each Tein H Tech lowering spring set comes with 4 springs, 2 for the front and 2 for the rear. Each Tein H Tech lowering spring set comes with a 1 year limited warranty.
    Tein H Tech Springs Product Summary:
    - Tein H Tech spring made from new strong, lightweight Vanadium material for optimal quality.
    - Tein H Tech spring combines a balance between styling and comfortable ride.
    - Tein H Tech spring comes with rubber spring protector tube to reduce noise.
    - Tein H Tech spring made with high quality powder coating and painting treatment to prevent rusting.
    - Tein H Tech spring made in Japan.
    - Tein 1 year limited warranty.
    Reference: Tein H Tech springs, Tein High Tech springs, Tein Guarantee Spec springs, Tein Guarantee Spec Luxury Master, Tein lowering springs.
    </B>
    FRONT REAR Spring Rate (lbs/inch)135/168 Ride Height Drop (inch)-1.4/-1.5
    Product Notes:
    Application: Tein H Tech Lowering Springs Kit Toyota Prius 2010-2012
