TRD Matrix 24mm Front Anti-Roll Bar
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Azipod, Nov 24, 2013.
  1. Azipod
    Azipod Member
    139
    NorCal
    Can anyone confirm that the TRD 24mm Front Anti-Roll Bar for the Matrix actually fits the Prius?
    I already have the rear put in. Finally, after several years of ownership, decided to do something about the Front. I'm debating whether to go with a TRD front-bar or just a stock Matrix/Corolla bar from Toyota.
    Thanks!!
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    stock matrix/corolla bar is 24mm. it will fit. the TRD bar i don't know about, but it should fit.
  3. Steven Harvey
    Steven Harvey Junior Member
    96
    Guelph On. Canada
    Remove the front and run without!
  4. 69shovlhed
    2,170
    746
    Delaware
    BRILLIANT IDEA! nothing better than uncontrolled body roll. doncha just love it when your car flops all over the place when you're in the twisties?
  5. Steven Harvey
    96
    Guelph On. Canada
    why couldn't you not just remove the front sway bar and just replace the front springs with stiffer progressive ones?
  6. 69shovlhed
    2,170
    746
    Delaware
    if you use springs so stiff that they will negate body roll, the ride quality will suck. unless you live in a place where the govt actually does their job and fills pot holes promptly (does a place like that even exist?) it'll pound your fillings out driving to work.
    for those of us stupid enough to live in the DC area, there are a bazillion pot holes / mile. so the sway bar does what its supposed to do, and still lets you have a reasonably smooth ride.
    the 24mm Corolla/Matrix bar works fantastic; anyone who has installed one will agree.
  7. Steven Harvey
    96
    Guelph On. Canada
    I don't have that problem here.
  8. 69shovlhed
    2,170
    746
    Delaware
    must be nice. canada takes good care of its roads huh? around here the idiots use so much road salt if they even think it might snow. seems like most people in this area are weather wimps.
  9. Steven Harvey
    96
    Guelph On. Canada
    yep my municipality just dumped millions into new roads in my city pretty much every road is brand new.
  10. Steven Harvey
    96
    Guelph On. Canada
    I will let you know how my car handles when I take the front stab bar off and put some Cusco or Ksport adjustable coil over on, and upgrade the rear stab bar.
