TRD Plus Rear Sway Bar
Discussion in 'Gen 3 Prius Accessories and Modifications' started by teamsc10190, May 5, 2013.
  1. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Just thinking about this sway bar upgrade... what's you're essentially doing is reducing the flex inherent in the trailing arm design by adding the sway bar. So essentially you are doing to the rear is making it stiffer(like a higher spring rate) as they work in conjunction due to sway bar. So is that the case, the rear end feels firmer?
  2. teamsc10190
    teamsc10190 Stereo Prii (2011 and 2006)
    145
    64
    My commute takes me 52 miles per day over a tight switchback mountain road. It's my Laguna Seca. The sway bar helps relieve the standard equipment ponderous understeer and body wallow that takes some of the drama out of the ride. The trade-off is the ride is a bit more jittery, and I've added about 20 lbs of unsprung weight that has to be dragged up and down the road every day.
    How it looks is another matter entirely. If appearance was part of the equation, the wheels would be the first place I'd have started.
    I continue repeating the mantra, "it's only a commuter car", and then the wheels are just peachy. If I could shave unsprung weight with alternative wheel/tire combo; that might be worth pursuing IMO.
  3. Sfcyclist
    1,621
    376
    SF, CA
    Got it.. makes sense. You're right.. for the money, hard to beat! (y)
    "Only a commuter".. some of us might take offense to that.. ;)
  4. Bullet Salvador
    109
    44
    Los Angeles
    I have a persona and about to install the ground effects kit. Do you think getting the sway bar and springs really make a difference? Moreover, does the car ride significantly lower and this hits and scrapes the floor? Thanks fellow persona. =]
  5. teamsc10190
    145
    64
    You're not just making the beam axle stiffer; you're essentially adding a spring steel torsion bar that resists being loaded with kinetic energy as it's twisted (when the body rolls).
  6. Sfcyclist
    1,621
    376
    SF, CA
    I can't speak for sway, but springs do.
    If you lower it, you will def. have a higher chance of scraping.
    Bullet Salvador likes this.
  7. Sfcyclist
    1,621
    376
    SF, CA
    Point being the left and right is stiffened up to act together by sway bar. You see it as resist compression, I see it as lifting the outside wheel. We're saying the same thing.
  8. Sfcyclist
    1,621
    376
    SF, CA
    Come to think of it, I have one that I can test drive with complete Plus package.. might just do that and report back if interested.. or perhaps start another thread...
  9. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I have only had the springs for a couple of days now. (I have been practicing stopping before the parking curbs...)
    Before the sping install, I had one scrape on the bottom of my front bumper. Luckily, it was just paint and I was able to remove it. However, I never had a problem with the ground effects scraping anything. I exited a driveway today that has a slight crevace before the street with the car tipping down slightly and I had no problem. One of the people at that office has a Hyundai Sports Coup with 17's and he scrapes on that exit. It's a couple of inches lower with the springs, but I haven't had any problem so far and I've driven 150 niles with them.
    What I can add is that the car definately seems more stable at 75mph. I wasn't correcting for sway, and on the way home, I had to take a turn faster than I liked. I let out the same, "Here we go..." as I always do when that happens and realized that the car tracked perfectly with no sway. Needless to say, I was very pleased and now instead of saying, "Here we go..." I just smile!
    During the spring install I was briefly invited into the service area. While under the car, I noticed the added under panels from the ground effects kit. (I wish I took a picture, but the service mgr. saw me in the garage and ushered me out for insurance purposes (&**!@#!!!) I noticed little fins attached to the panel to direct airflow. I am assuming that with the ground effects kit and the lowering springs, the added aerodynamics may assist in off-setting some of the mpg loss from the extra weight of the the ground effects, 17's and anti-sway bar. I have to log my trips for business purposes and I did edge out 2mpg more via the display then I usually get to and from my destination of 57.1 miles, mostly between 50 and 75mph.
    So, do I think you'll have a problem scraping? You will obviously increase your chances with the springs. But, IMHO, I don't think it's TOO low and driving carefully will reduce the risk.
  10. came_to_party
    came_to_party Junior Member
    48
    I don't think anyone has asked this, but, when you did the install, did you have to purchase some bolt kit or something. I've seen conflicting results on this and would love to know.
  11. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The TRD kit I bought came with everything that was needed.
  12. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    I completly agre with where you are going but because it does not mount to the unibody you don't get as much of that push-pull counter effect dynamic as you get from a "traditional" anti-sway bar. While i completly agree the TRD rear sway bar does an amazing job reducing body roll I see it more of a rear beam stiffener then a true to the roots sway bar. Non the less, it's an amazing upgrade for the money.
  13. came_to_party
    48
    I don't mean to hijack your thread but since it's gone cold I'm hoping someone can help me out. I installed my rear sway yesterday and it's making a God awful clanging and banging noise when I go over bumps. When i get under the car I can't see where it's touching any metal to produce this sound and so I'm completely stumped. I did make sure to adequately lube up the bushings and all the nuts are tight so I'm lost on what's going on here. any advice or help would be hugely appreciated.
  14. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    Did you disconnect the struts at the bottom in order to install the end links?
    If so, did you tighten them back up with weight on the tires as per the instructions?
  15. teamsc10190
    145
    64
    Hard to speculate where you may have gone wrong without photos.
  16. peterjmc
    917
    189
    Clarksburg, MD
    +1. Can you take close pictures of both endlinks, and both bushings for us? Maybe we can tell you by visual inspection of the photos.
  17. came_to_party
    48
    I did take the struts off the bottom to install the endlinks, I did NOT put the wheels back on when I was re installing the bolts. I'll do this when I get home and take pictures of everything.
    Thanks for the quick responses folks!
    EDIT: I completely missed this line in the instructions
    "1. This bolt must be tightened with the load of
    the car on the tires.
    2. If using a post lift or jack first lower the
    vehicle and bounce it up and down several
    times to stabilize the rear suspension."
    Question though, how do I bounce the car up and down several times? (I'm probably reading too much into this)
    Ken Blake likes this.
  18. peterjmc
    917
    189
    Clarksburg, MD
    Just sit in the rear hatch area and bounce yourself up and down. You could use any other method that would make the car bounce up and down in the same manner.
  19. came_to_party
    48
    i can think of a few things...
    Russ McBride and Totmacher like this.
  20. Ken Blake
    351
    180
    Portland, Oregon
    Aha! That is what I suspected. I installed the end links without removing the struts in order to avoid this step. The only reason they have you unbolt the struts is to make room for your hand and the nut when installing the end link. Unless you have fat fingers, there is adequate room to complete this step without unbolting the strut.
