TRD Rear Sway Bar from dealer for $78 (CAD). What!??
Discussion in 'Prius c Accessories and Modifications' started by Issy Car, Oct 7, 2018.
  1. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    Well, whole project on hold. Seems you can't trust everything you read on the internet! :unsure:
    I ordered the Whiteline BTR77. Manufacturers site says it doesn't fit the C. Other vendor sites (at least 3 separate ones) say it does.
    When I got it in my hands and checked under the car I could see it doesn't fit the C.
    Waiting on my return instructions now.
  2. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Bummer, yeah searching the part number it comes up with the early 2000's Corolla or the Lexus CT.
    The C would need something shaped more like:
    Cusco:
    TRD:
    Ultra Racing:
  3. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    I think it will be the TRD once I get the return settled.
  4. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    I have a question for anyone here who has installed the red TRD sway bar. My bar is on the way BTW!
    Question is, do I need to jack up the car to install the bar? I have ramps and was hoping I could just do that. Just don't know how much the springs will compress if I take off the bolt for the rear shock like the install instructions say. Thanks all!
  5. bluekona
    bluekona Junior Member
    Oregon, USA
    No. I installed mine without lifting the car at all.
    Took about 10 minutes with hand tools only.
    14mm combo wrench and a 14mm socket/ratchet.
    You don't even fully remove the bolts for the shocks, just the nuts.
    ztanos and Issy Car like this.
  6. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    I found the same info after searching around too. But nice to hear it first hand. Thanks!!
    bluekona likes this.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I was going to say this... but it had been a while since I'd done mine and couldn't remember for certain. Thanks Blue.
    Issy Car likes this.
  8. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    Thanks for your help Blue, ztanos, and Brandon
    Done today.
  9. Mendel Leisk
    41,473
    Does that push the rear wheels out a bit, just curious?
  10. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    Not at all. I didn't unbolt anything that would move the wheels.
    It attaches to part of where the rear shocks sit and also bolts to existing holes in the shock frame.
  11. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    I need to re-torque my sway bar after three years of usage. Can anyone paste up the manual or tell me the torque setting for the bolts? Thank you.
  12. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    The instruction sheet says torque the bolt that is attached to the rear shock to 36 ft lbs.
    Torque the other bolt to 44 ft lbs.
    Sparks parts has the PDF if you want to see it. Here.
    ztanos likes this.
  13. Subaru
    Subaru New Member
    Indianapolis
    2018 Prius c
    Anyone know if there is a larger diameter front sway bar available?
  14. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Cusco makes a front and rear set. I've been thinking about ordering them and letting the TRD rear go.
  15. Subaru
    Subaru New Member
    Indianapolis
    2018 Prius c
    Thanks, just ordered the TRD rear. I can’t justify the Cusco tax just for a matching set.
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Do you have the TRD front? If so, are you also thinking about letting it go?
  17. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Nope rear only from TRD
  18. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Dang, I already have that one. :D
    Brandon Most likes this.
