TRD Rear Sway Bar
Discussion in 'Gen 3 Prius Accessories and Modifications' started by kmkremer, Dec 4, 2013.
  1. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    The one for the XB will also work FWIW.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I don't see why in this case. On level ground there is no load on the bar or links.
  3. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    Install was a breeze. I will road test in the morning.
    iPad ?
  4. uccrev
    uccrev Junior Member
    Rented time on a drive on, four-post lift to install the TRD anti-sway bar. Hardest part for me was torquing the end link in the lower shock mount. Also installed a front chasis brace and swapped the mid chasis brace for a stronger one. Big improvement in stability and steering.
    ScottHz likes this.
  5. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    IT WORKED! My Prius drives fantastic now.
    ScottHz likes this.
  6. xpcman
    1,302
    295
    I made the same mods as you. The front brace was the last part added and I was surprised at the improvement. The 2010's front and mid brace were improved in later years. So they may not be needed as much after 2011.
  7. nicoj36
    nicoj36 Active Member
    518
    162
    Sorry to bump a really old thread but I have a question for @Technigogo, I am planning on installing the TRD rear sway bar and i also have the wandering in highway speeds as well.
    Did it completely get rid of the wandering for you? is it night and day difference?
    Im also thinking about getting the front and mid brace some members on here talk about. You think I should get it to to make sure I would get rid of my wandering? or is that overkill and the rear sway bar is enough?
    I'd appreciate your input man.
    Again, apologies for re-bumping an old thread. I cant pm the person due to his privacy settings :D
  8. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    At the time, it was noticeable. What I found later is that the "float" and"wandering" was exacerbated by high psi, fuel saver type tires. In the beginning, I was pretty smitten with achieving as high of an MPG as I could. After that novelty wore off, I stopped running my tires at the top end of the sidewall maximums. I think that had more impact on the floating.
    Years later, I still appreciate the sway bar because I feel like the car handles tight and I drive it like a bat out of hell.
    Pixel 3 XL ?
    nicoj36 likes this.
  9. orenji
    orenji Senior Member
    5,887
    3,488
    Had mine installed last week, thanks Hybridpit! Amazing difference, car stays flat through the curves! Highly recommended :)
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  11. nicoj36
    518
    162
    @Technigogo
    Do u have the 15 inch wheels or 17? Also, what kind of tires are you running?
    Im really determined to get rid of this unstable swaying completely. I cant stand driving with the sway because of my ocd. I feel like i cant relax and have to constantly counter-steer the steering wheel just in my typical daily driving. I already installed the RSB and it helped a little but its still there. I have michelin defender tires and i only have the psi set at 32. Also, i just had a wheel alignment 2 months ago.
    Im thinking of installing a strut bar, new front sway bar links, and both inner and outer tire rods. If that still does not fix it, i will purchase a lighter aftermarket wheels at 17 inches and low profile tires to finish my fix. Hopefully that does it since i have heard on here that 17s wheels provide way better stability than the 15s.
    Thoughts? Ty..
  12. ASRDogman
    ASRDogman Senior Member
    7,920
    4,026
    Maybe you have worn tie rods ends or sway bar bushings, front and/or rear.
    Or ball joints. OR wheel bearings. Or all are slightly worn.
    They should have noticed it when they did the alignment.
    Any or all of the above will cause you to wonder all over the road.
    With electric steering, you might have a problem with that.
  13. douglasjre
    douglasjre Senior Member
    2,223
    743
    Null, NL
    What was your final result on the swaying and installing a sway bar?
  14. nicoj36
    518
    162
    It definitely improved it but the issue was the software/ECU. After I performed the reset that's what really fixed it and not the sway-bars.
    douglasjre likes this.
