TRD spring for my Prius icrease the handling? Or ruin my tire first?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sting30380, Nov 25, 2011.
  1. sting30380
    sting30380 New Member
    Houston, TX
    Has Anybody ever replace your factory spring with some TRD or other aftermarket spring? I just recently got some 17'' aluminum alloy wheel for my 2010 Prius and there is a gap between the fender groove and my wheel. The local Toyota dealership actually sells these TRD spring for performance modification. But I am worried about once I use these TRD lowering springs or "drop low" the car, the tire will start to wear out unevenly. Has anybody try doing that before? Please advise, thanks... :confused:
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    A lot of people have lowered their Prius. Try using the search function to read those threads. There are other spring manufacturers besides TRD.
    After lowering your car you should have an alignment performed. This will keep your tires from wearing out prematurely.
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  4. Danger
    Danger Member
    175
    22
    Frisco
    A couple of ppl report that the Performance Plus package springs lower 1.2". It is the TRD Sportivo suspension that lowers 10mm.
  5. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    From what I understand about the TRD suspension, it doesn't lower the car very much at all.
  6. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    674
    179
    Vancouver, WA
    I didn't want to slam my Prius so I went with the Eibach springs. I was able to order them today from AutoAnything.com & get 15% off plus free shipping on Cyber Monday. There is also a $20 rebate from Eibach so my net price will be around $165 them. :D
    I just wish that I could find some wheels that I like in a 17"x7" that are not too heavy. :(
