TRD Springs installed - with 205/50/17 tires
Discussion in 'Gen 3 Prius Accessories and Modifications' started by F8L, Oct 21, 2012.
  1. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Th
    That was the sunny side of the street! Blame my cell phone. :p
    sfv41901 likes this.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Ur gonna love the the way ur car handles now.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Interestingly, it doesn't really feel much different. It wasn't the night and day difference like in my GenII. That's ok. I wasn't really looking for performance. I wanted the look and comfort.
    Now the car looks like it should have from the factory. Clean and OE-like. :)
    Unfortunately, it is supposed to rain this week so I won't be able to clean it up and get real pictures until next week. :( People are going to think I took the pictures in the dark!
  4. SoCal65SS
    SoCal65SS Member
    72
    44
    Southern California
    Only 2 1/2 hours for the full install?? I'm impressed! I've done suspension on my Chevelle multiple times, lowered my Audi and then put it back to stock and I think I would seriously have to work very hard to swap out springs that quick! The lowered pic looks great btw!
  5. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    What have I missed? Where are the pics?
  6. SoCal65SS
    SoCal65SS Member
    72
    44
    Southern California
    He added the lowered pic to the 1st post. Very bottom :cool:
    F8L and a priori like this.
  7. a priori
    3,083
    407
    23
    Chicagoland (West)
    Thank you!
  8. a priori
    3,083
    407
    23
    Chicagoland (West)
    Looks great, F8L.
    Ever thought about putting 17s on that baby?:cool::giggle:
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    :p
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Pretty close. We ran into a bit of a snag when 2 of the 10mm bolts that hold the cowl on snapped leaving the bolt threaded in the body so we had to remove the cowl again and use needle nose pliers to reverse the broken bolts out far enough to grab it by hand. That killed about 15min or so.
    Mike brought so many tools it was not even funny! He had a 20v impact gun for Christ sake! He has done this install a few times and knew the sequence quite well so I just tried to mimic what he did on the opposite side or i would take things apart while he torqued other stuff down. He did the vast majority of the work though. I just did my best to document our progress and get in his way.
    We even had time to take a test drive then bleed his brakes three times with the Techstream and he went for anther test drive and packed everything by 4pm. :)
  11. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
    So how is the ride, is it confi ? softer than stock by any chance ?
  12. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    My new IR W7150 certainly made the job a lot faster...and more fun. :D
    Cordless Impact Wrench - W7150 - Ingersoll Rand Cordless Tools
    sfv41901 and SoCal65SS like this.
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It is pretty soft as far as lowering springs go but I notice it is more bouncy than I first thought. I drove to Davis tonight and I was a little disappointed but it still drove well so I'm not unhappy enough to want to change anything. I bet that within a week or so I'll be used to it and won't even notice the bumps anymore. Due to the lower temps my tires are at 35/34 right now.
    I guess is should say it is soft like stock but bouncier. Hitting a hard dip on the highway was enough to elicit a comment from my girlfriend. It's not that bad overall. I wouldn't want to drive this with those PureContact tires and high tire pressure though!
  15. The Critic
    3,193
    2,321
    CA
    Most of the bounce will go away once you have the vehicle aligned, seriously.
    F8L likes this.
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Sweet! I'll likely have it done two weeks from now. :)
  17. WE0H
    WE0H Senior Member
    3,247
    527
    My car has kinda fast rebound. Mike mentioned alignment will fix that. Explain how the alignment can slow down the rebound dampening. Now I am wondering if the port install people aligned my car after installing my suspension.
    Mike
    Mobile on my SGH-i717
  18. The Critic
    3,193
    2,321
    CA
    I've found that if there's a ton of toe-out, the front end feels exceptionally bouncy over bumps and potholes. Just personal observation though.
  19. WE0H
    WE0H Senior Member
    3,247
    527
    That is something I can measure at home :) I will check that next week and let you know.
    Mike
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
