TRD sway bar worth it?? Or TRD drop springs??
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jk818, May 9, 2016.
  1. Jk818
    Jk818 Member
    Hi all. Just got my Prius About a week ago and I'm loving it!... I was looking at the TRD sway bar and drop springs... Any feedback??
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,460
    92
    I love mine. I also got the Cusco front sway bar for an extra dose of flat cornering awesomesauce.
    RollinBad, Xterra72 and RightOnTime like this.
  3. Jk818
    Jk818 Member
    Thx for the input Dylan! Found them on oempartworld.com. Decently priced by my findings. How low of an actual drop do you think the springs have you?
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    He doesn't mention springs, but the trd's I understand drop .9", I put the rear lower sway bar on, it helped.
  5. Jk818
    Jk818 Member
    Thanks lucifer
  6. Dylan Doxey
    1,389
    3,460
    92
    The TRD springs give you between 1" to 2" drop. It's enough that caution is called for when going over speed bumps. And if there is more than two adult men in the car, I'll ask them to get out before crossing a significant speed bump.
  7. Topp Cat
    Topp Cat Member
    71
    66
    i had TRD springs on 17 oem wheels on toyo A20 tires Harsh ride , scrapping over speed bump, a very unpleasant driving experience! Change over to regular RSR springs ! Ahh lot better now! With a slight 1 inch drop alround. Before TRD sway bar speeds above 60 mph I feel the car would drift left to right depend on the road surface conditions! After the sway bar installed it elimated the drifting issue. I belive the torsion bar too soft bending up the down depending on your rear alignment and thrust angle will affect the rear tracking, compare to our volt and fiesta ST the rear torsion bar is solid round tube vs Prius u shape bar.
    #7 Topp Cat, May 9, 2016
    Dylan Doxey and Jk818 like this.
  8. Jk818
    Jk818 Member
    2" seems pretty low. I'm in MN so still thinking if I will drive during the winter. Just bought some blizzaks on CL tho if I want to
    Jon Senum likes this.
  9. Jk818
    Jk818 Member
    How much are the rsr springs?
    Dylan Doxey likes this.
  10. FinToy
    FinToy Active Member
    145
    141
    Finland
    Knowing the roads here, that's the reason why my springs are still in a box in the garage...
    Actually, I'm having problems getting my jack to fit under the car even with stock springs. What happens if I drop the car... :eek:
  11. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
    I'm on TRD springs. Gives me 1.1 drop in the front and 1.5 in the rear. I'm on 18x8 rims with 225/40 tires with 10mm spacers in the rear. The ride is definitely harder, however, it's not bone jarring hard. It's livable. Also, as far as bumps go, sure, you have to watch out for bumps...as with any lowered ride. Even a stock Prius has to watch out for heavily slanted driveway.
    Z.
  12. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    I vote for rear sway bar.
  13. Dylan Doxey
    1,389
    3,460
    92
    Everyone's preferences for ride feel tend to vary. But in my opinion, the TRD rear swaybar is a winning choice for anyone. It doesn't make the ride more harsh while providing a noticeable reduction in body roll on cornering. In the case of extreme performance demands (such as autocross competition) you would need something more stiff.
    I've been told that many people feel that the TRD springs are too bouncy and will eventually change to some kind of coilovers. Having used my TRD springs for several months now I can see how people might feel that way. But in my opinion, the TRD springs are a fair compromise that improves handling while still preserving much of the OEM feel and ride height.
  14. granTORRESmo
    237
    648
    Norcal
    I went from tanabe nf springs to tein springs to rsr coilovers. The best upgrade through this whole time was the TRD rear swaybar
    HelloHybrid, Jk818 and Dylan Doxey like this.
  15. Jk818
    Jk818 Member
    Thanks for the input guys. I want to stay OEM as much as possible. Does it matter if I get sway bar or the springs first??
  16. granTORRESmo
    237
    648
    Norcal
    No it doesn't matter and I'll say go for rear swaybar first. If you want the most comfortable lowering springs, get tanabe NF springs. It's so OEM, I replaced it with tein hTech lol. I think the spring rate is pretty close to OEM springs and it's less than an inch drop
    #16 granTORRESmo, May 10, 2016
  17. Jk818
    Jk818 Member
    With 1.5" drop any camber issues??
  18. granTORRESmo
    237
    648
    Norcal
    No issue, it's still in tolerance with Toyota camber specs. You're still good
    #18 granTORRESmo, May 10, 2016
  19. trip1027
    trip1027 Member
    106
    27
    wyoming
    Drive on a 2x6 with front tires helps alot
    SM-N920V ?
  20. Jk818
    Jk818 Member
    Why did you switch from tanabe to tein??
