TRD sway bar worth it?? Or TRD drop springs??
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jk818, May 9, 2016.
  1. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Lol I wasn't satisfied with the height. Tanabe NF lower only 1" and the spring rate was too soft like OEM springs. I wanted something more sporty and lower, and that why I switch to teins.
    And also check the image I have.
    #21 granTORRESmo, May 11, 2016
    CoolPrius likes this.
  2. Jk818
    Jk818 Member
    Thanks @granTORRESmo! Good info!! Gonna keep researching til I kno what I really want for springs. Gonna get the sway bar first for sure
  3. FinToy
    FinToy Active Member
    145
    141
    Finland
    Sure does but I'm too lazy for that :LOL:
  4. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    TRD RSB was the most noticeable single suspension improvement mod through my personal experience.
    Current suspension is TRD Springs, TRD RSB, RAV4 FSB, Mike's Mid & Front Under Braces, Cusco Top Mount Strut Bar & 17" Wheels.
    Jk818, granTORRESmo and Xterra72 like this.
  5. Jk818
    Jk818 Member
    Ho
    How do you like the TRD springs?
  6. Topp Cat
    Topp Cat Member
    71
    66
  7. RollinBad
    RollinBad Member
    46
    72
    Oside, CA
    You're so right. I put my RSB on earlier this week and now I notice how much the front flexes now I need that front bar!!
    Dylan Doxey likes this.
  8. Krish Udvadia
    Krish Udvadia Junior Member
    Westlake Village
    did you install the front and rear differently?
  9. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I am not sure what you're asking?
    The installation procedure for the front and rear sway bars are very different, yes.
  10. Krish Udvadia
    Westlake Village
    No i mean did you install the rear sway bar then drive or around and then install the front sway bar at a later time and see how that made an improvement?
  11. Jk818
    Jk818 Member
    I keep going back and forth either tein or TRD springs. Which do u think will be more comfortable?road conditions in MN are kinda rough
  12. Dylan Doxey
    1,389
    3,459
    92
    After I installed the rear TRD swaybar I was pleased with the results. There was a noticeable reduction in body roll on hard cornering. That's when I decided to order the front Cusco swaybar. The Cusco front swaybar further reduced body roll on hard cornering.
  13. Krish Udvadia
    Westlake Village
    How did the car act with the front one on
  14. Jk818
    Jk818 Member
    When you installed the rsb... Did you purchase the bushing kit as well??
  15. Dylan Doxey
    1,389
    3,459
    92
    The bushings were included. I purchased Amazon item B007Z73M4W in May 2014. There's a note there that you need to purchase and end-link kit. But it was included in my case.
    Jk818 likes this.
