TRD sway rear sway bar, which one ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Sushi_1001, Nov 7, 2011.
  1. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
    Can you explain a bit more about how the car feels before and after this upgrade ?
    (I am really interested)
  2. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    The rear of the car feels more planted and controlled. Body lean from the rear during cornering is greatly reduced. On grooved highway lanes the car is easier to control became the rear does not quiver and tramline like as much as it once did.
  3. ockevin
    ockevin Active Member
    493
    148
    Orange County
    I have the TRD springs and rear sway bar and love the handling. I have the PLUS package and its a great handling car. The on ramps on Freeways are much better than a stock body roll Prius. I cant say enough about how much better the TRD suspension parts are over a stock Prius.
    2 people like this.
  4. EdyJun
    58
    Los Angeles
  5. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    which one is better the 2012 trd one or the 2008 scion one ?
  6. The Critic
    3,193
    2,321
    CA
    TRD prius one only because it is white (I despise red) and it is the proper part for the vehicle.
  7. d0nsut
    d0nsut New Member
    28
    Houston
    Ya, I ordered mine Friday because of the 'proper part' thing.
  8. nedear88
    nedear88 My 1st Prius.
    245
    140
    San Bruno, California
    Hello,
    I have a question for you, since I read the post you installed the TRD sway bar, do you have to remove the rear shock absorber lower bolt in order to tighten and torque the endlink bolt? I just ordered mine from local Toyota dealer quoted $250 plus local tax, I am planning install it myself. Your reply is greatly appreciated. :D:thumb:
    Regards
    Tony Lu
  9. The Critic
    3,193
    2,321
    CA
    Yes, that is the preferred procedure. Be sure to only finger tighten the shock absorber bolt when the car is in the air, and do the final tightening once the car is back on the ground.
    MB860 ?
  10. MD80
    MD80 New Member
    32
    Owasso OK
    Sweet so we don't actually need to order the mounting hardware kit ?
  11. The Critic
    3,193
    2,321
    CA
    Correct.
    MB860 ?
  12. jaredy
    jaredy Member
    162
    SoCal
    Do you have any installation instruction? I would like to see if I can do it myself without much tool.
  13. The Critic
    3,193
    2,321
    CA
