Tree droppings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jul 11, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    What about sewing machine type oil ?
    Nexus 6 ?
  2. Mendel Leisk
    42,345
    I don't think so. If you're goal is to find something more readily available, maybe WD40.
    It's funny that kerosene seems now to mainly be available in larger volumes; you don't need a lot. Camping supply stores?
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Definitely not charcoal lighter fluid. Gas stations don't sell kerosene like they used to.
    If you don't already have anything around the house buy "tar & road oil remover". The can I have says it contains ethylbenzene, xylene, and petroleum distillates. You'll eventually need it to get the road crap off your rocker panels.
    Never rub or scrub a painted surface as your are likely to cause scratches. If they aren't too far down in the paint ScratchX can work. I don't know about any of the products that claim to be able to restore any color.
  4. Taxi/Limo
    526
    107
    Thanks guys what's the least damaging to paint the bug and tar remover or the kerosene ?
    Nexus 6 ?
  5. Mendel Leisk
    42,345
    ^ Oh hey, perfect. And comes in small bottles.
    Either would be fine.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...fyi we have had a number of prior threads on cleaning tree sap ...search on "sap" for some examples
  7. Taxi/Limo
    526
    107
    Thanks all well I tried turtle was bug and tar I sprayed some on and let it set 5 to 15 minutes I did not work very well then. I added a little car wax into the mix and gently rubbed the little spots with a microfiber cloth that did not work very well either
    I then washed the car to get all the stuff off and spots started coming off as I moved the wash not over the car
    My question is why did that work? Was it the process of bug and tar / wax then wash ?
    Or maybe just the soap and water acted as a solvent
    There are still a lot of little spots but I think another wash might be the next step and then something else
    Nexus 6 ?
  8. Taxi/Limo
    526
    107
    Turtle wax bug and tar. Wash mit
    Nexus 6 ?
  9. Taxi/Limo
    526
    107
    I should add I used my fingernail and finger tip to nudge the little spots as I washed which was very effective
    Nexus 6 ?
  10. Mendel Leisk
    42,345
    Sounds it's slowly coming off! I'd think it's more tenacious due to sitting a month.
  11. Taxi/Limo
    526
    107
    Once I get everything off a coverking car cover goes on
    Nexus 6 ?
  12. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Have you tried clay like others have suggested at the beginning of the thread? They are designed to take out whatever a normal wash doesn't take out. I'd do that before using harsh chemicals on your paint.
  13. Taxi/Limo
    526
    107
    I did not think bug and tar was harsh and the spots are pretty big I will try the clay I once I get it but I am not sure if it will work on the larger stains
    At any rate I am slowly getting the car back to normal I hope
    Nexus 6 ?
