triangle but no codes
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Aug 12, 2026 at 1:25 AM.
  1. ronlewis
    ronlewis Active Member
    1,061
    205
    texas
    2001 Prius
    Haven't had this before. Car started up fine and a minute later threw the triangle. No other lights, not the big screen, just the triangle. I'm not pulling any codes with TorquePro. IIRC, being low/high on oil can trigger a no-code triangle, but the oil level is exactly right. Anyone know anything else that sets the triangle but doesn't throw a code? The inverter pump is working fine. Car runs fine, although I only drove it a couple of blocks and came back home.
    TP clears the triangle, but it sets again, whether it's driving/in gear or just idling. Can't recall for sure, but I think it sets with just the key on, without starting it.
    Any other way to read the codes? I don't have TS.
