Triangle of death and scangauge
Discussion in 'Generation 1 Prius Discussion' started by wwu123, Aug 9, 2010.
  1. JJLINK
    JJLINK Junior Member
    2002 Prius
    I
    For some reason my 12 volt battery was dead. I suspect I left the door slightly open overnight and most of the next day.
    So I charged it up and when I started it up I got the Triangle of Death and the flashing ABS light.
    This morning the 12v battery is fine but I still got the TOD and the ABS light. I shut if off and tried a couple more times and got the same deal.
    I shut the car off removed the ScanGauge II and started it up with no TOD or ABS lights on.
    This is a 2002 Prius which had the battery array replaced a couple months ago.
    I saw some posts about the Scangauge and a different cable.
    Could the Scangauge cable be part of the problem?
    It seems like disconnecting the ODB-II cable and plugging it back in has cleared up the issue for now.
    I have been using the the Scangauge since mid-September and seen this a couple of times now.
    Any Ideas?
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi JJLINK,
    Actually, there is nothing wrong with the SG cable. Many of the other multi-protocol scanners, e.g. AutoEnginuity, also has the same issue with our Gen1.
    Gen1 uses pin 14 of the OBDII connector for Ts signal. When Ts is shorted to CG (Chassis Ground, pin 4) while turning the ignition ON, the car will initiate the sensor signal check (Test Mode) by blinking the ABS warning light. If you used any multi-protocol scanners, pin 14 is being used for CAN Low signal. When the scanner is trying to auto-detect which protocol the car uses, the CAN Low signal may go low momentarily and the car detects that as a sensor check and blinks the ABS warning light.
    As a workaround, you can either cut pin 14 or use an adapter if you intend to use your SGII for other vehicles.
    Vincent
  3. ChapmanF
    18,215
    LinearLogic (the Scangauge people) sent me a suitable cable at no charge when I asked, which also leaves the original cable for use in other vehicles, and saves the trouble of making an adapter.
    -Chap
  4. bobofky
    bobofky Member
    107
    Remember that the security system is drawing power from the 12V while the car is setting. I have found that my 2001 Prius ECU is very sensitive to the 12V battery power. I have had problems similar to what you describe and put a battery charger on the 12V battery until it is fully charged and the problems went away for months. Eventually the 12 V deteriorates and the problems return.
  5. wwu123
    wwu123 Junior Member
    62
    Thanks for the suggestion, I had given my car to my parents to use for the last nine months, but I have it back for the next three months. I had replaced the 12V battery a few years ago with one of those Optima spiral batteries, so I thought I was fairly good there (plus I monitored the battery voltage with Scangauge). Nonetheless my parents had some problem with the car a few months ago and the dealer said the 12V battery was no good and replaced the Optima.
    The car will be sitting for weeks at a time outside in cold damp weather, and this time of year is ideal to see if the problem is gone now, with the 12V battery change. Unfortunately it's not a controlled test as my parents insisted in September that we replace the traction battery as well (done with a rebuilt battery at Luscious Garage).
    I started a new thread with a different, likely unrelated problem - we now see fault codes after around 300-400 miles of continuous, highway driving. That's yet another mystery...
  6. w2co
    w2co Member
    366
    81
    Longmont, CO.
    "The car will be sitting for weeks at a time outside in cold damp weather" That's not good for either battery, disconnect the negative of the 12V and pull the service plug for the hv pack. It will last longer, but I don't think weeks under these conditions is an option. Before you pull the plug, make sure your SOC is as high as possible. Try to drive the car once in a while to properly "cycle" the pack.
