Triangle VSC (!) Lights on no pending codes
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Apr 13, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    Have driven my Prius about 60 miles since changing the HV battery and all these lights just came on.
    Haven't hooked up tech stream however used torque pro and my maxilink ML619 and see no stored or pending codes across the entire car.
    52,862
    hook up tech stream
    Raytheeagle likes this.
  3. Banksy
    415
    133
    I have absolutely no idea what I'm doing in tech stream. However I'm using common sense
    Seeing these codes
    P3000 battery control system
    P0A84 Hybrid Battery Pack Cooling Fan 1 control circuit low
    52,862
    that's the ticket
  5. Banksy
    415
    133
    So that's basically saying there's an issue with the battery control system
    And the fan cooling it
    By that does it mean the computer for the battery is having an issue? Or is it just the fan possibly?
    I couldn't get tech stream to test the fan
    However the ancient laptop I'm running this on had the battery die.
    So I will attempt to test again
    Side note
    THIS SOFTWARE IS COOL!
  6. Banksy
    415
    133
    On a side note if this helps I DID check the HV battery ECU connector before finishing the battery installation.
    It didn't look dirty or corroded.
    However I will also say the fan was absolutely filthy before I cleaned it out.
  7. ChapmanF
    19,033
    The codes are coming from different computers.
    The P0A84 is coming from the computer inside the battery, and it's telling you about a specific problem. Probably something to do with control of the fan, but those one-line fortune cookies usually aren't enough to pin down the problem. Looking up the code in the repair manual (more info) and following the troubleshooting steps given there will usually do the trick.
    The P3000 is from the hybrid control computer up in the front of the car. It's just telling you that it heard the battery computer has something to tell you, which would be the P0A84.
  8. Banksy
    415
    133
    So odds are these codes are related to each other.
  9. ChapmanF
    19,033
    It's not odds. P3000 is a hybrid ECU code that literally means "go deal with your battery ECU code."
    Banksy likes this.
  10. Banksy
    415
    133
    I like your style.
    I'll take a look at the connector for the can tomorrow and check for corrosion.
    I'll also try testing it though techstream if that's possible
    Very new to this software
  11. ChapmanF
    19,033
    I haven't looked at the repair manual workup instructions for P0A84 recently. That would be a worthwhile step. It might tell you that some of the things you are planning to check won't tell you much about this problem, while other checks you're not thinking of would.
  12. strawbrad
    953
    1,007
    A common problem with the Gen 2 Prius is leaky rear hatch seals. Often these leaks lead to the wiring for the HV fan. Check the plug next to the fan. They can rot away from getting wet.
  13. Banksy
    415
    133
    Now that you mention it... I noticed water in the rear of this car when changing the battery. Right where that compartment is on the driver's side next to the storage bin.
    I was wondering how that got in there.
    When I was replacing the HV battery didn't notice any water on the passenger side where the fan and wiring is located.
    However I will definitely be checking this tomorrow.
    What's the best fix for the leaks?
  14. strawbrad
    953
    1,007
    The cheap fix is small holes drilled in the low spot where the water is collecting. These are old cars.;)
  15. Banksy
    415
    133
    Dude where were you a month ago
    I'd take a new set of modules all day long for 850.
    I feel like I got ripped off now )':
    #15 Banksy, Apr 13, 2020
  16. Banksy
    415
    133
    Also where do you get a key for this?
    Oh NVM got it off Reddit
    #16 Banksy, Apr 14, 2020
  17. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    I doubt Brad is selling new cells modules HV batteries for $850. More like a top-notch reconditioned HV battery, which I still would take given the correct use-case scenario.
    If they were new, well, that would be something else!
  18. Banksy
    415
    133
    do not know what shipping is but if the quality is there that's a great deal
    I went with 2nd life batteries due to the price and recommend off here
    In tech stream they all were very very close voltage wise. do not know if that's a sign of a gooden or not but looks good to me
  19. dolj
    dolj Senior Member
    8,646
    4,398
    It is certainly a plus until they aren't. Long may it be that they remain close in voltage and capacity (which is as important also).
  20. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The bottom plastic ventilation duct for the battery has a sensor in it. Perhaps that sensor helps control the fan? Did you disconnect it when you disassembled the rear of the car to remove the battery? Perhaps you forgot to plug it in when you reassembled the car.
