Tricking engine into running
Discussion in 'Gen 2 Prius Technical Discussion' started by DWJM2513, Jan 24, 2021.
  1. DWJM2513
    DWJM2513 Junior Member
    64
    24
    US
    The Hybrid batteries in my 05 Prius are in the red triangle stage. It hasn't been running in probably 8-10 months now. Is there a way to trick the engine into running or at least cranking over to keep things moving till I can get new batteries into it? Thanks! Screenshot_20191130-163412_Dr%20Prius.jpg 20200409_181610.jpg
  2. PriusCamper
    PriusCamper Senior Member
    13,475
    5,440
    Pacific Northwest, USA
    Oh, I see you're in Ohio... If the hybrid battery has enough power to start the engine you can force charge the battery, but once the battery can't start the engine and you have failed modules you need to pull the pack and charge up each of the still healthy 8v batteries. There's 28 of them and one of these inexpensive chargers and an old laptop power supply for it will allow you to charge everything up: iMAX B6 V2 Changer
    There's lots of youtube videos on how to do all that...
  3. DWJM2513
    64
    24
    US
    What kind of price are we talking about with that charger? It won't show me any prices
  4. PriusCamper
    13,475
    5,440
    $30 available from many places... Make sure you get Version2, it's way better than Version 1.
    Power supply not included!
  5. DWJM2513
    64
    24
    US
    Yeah I just found it on Amazon for 50 bucks. Thanks for the help man!
    PriusCamper likes this.
  6. DWJM2513
    64
    24
    US
    Hmmm it shows the power supply is included Screenshot_20210124-220741_Amazon%20Shopping.jpg
  7. PriusCamper
    13,475
    5,440
    $50 is too high... And if you buy more than one it will go much faster... I have 7 of them.
  8. PriusCamper
    13,475
    5,440
    That's the wrong one, that's version one. It has a power supply inside it which causes overheating... Version one also has a really slow processor and less power so it's easier to overcharge/ruin a module with those ones.
  9. DWJM2513
    64
    24
    US
    It says V2 up top though?
  10. PriusCamper
    13,475
    5,440
  11. PriusCamper
    13,475
    5,440
    yeah that's v2 of the 60w version, not the newer 80w version2.
  12. DWJM2513
    64
    24
    US
  13. PriusCamper
    13,475
    5,440
    nope... In this pic below you can see 3 of the new 80w V2 ones that are almost twice as fast and 4 of the old 60w ones that run too hot because power supply is inside the case and have slow processors which heat modules up too much.
  14. DWJM2513
    64
    24
    US
    Okay this is the only 80w one that I found. This the right one? Screenshot_20210124-221949_Amazon%20Shopping.jpg
  15. PriusCamper
    13,475
    5,440
    Nope, that's version1 of the one that doesn't have the power supply...
    And I spoke in error when I said 80w, I meant 60w... Specifically:
    V1 = 50w / 5amp
    V2 = 60w / 6amp
    I can't stand Amazon's monopoly and the way they steal everyone's business and act like their own government by taxing/financially punishing people who don't do business with them exclusively. They need to be broken up under existing anti-trust laws.
    But you seem to be determined to buy from them so here's a couple links that work:
    https: //http://www.amazon.com/Genuine-Professional-Battery-Balance-Charger-Discharger/dp/B071JPQ7Z1/
    https: //http://www.amazon.com/SKYRC-Balance-Charger-Batteries-Charging/dp/B0822RM9VJ/r
  16. DWJM2513
    64
    24
    US
    I mean I'll buy from anywhere as long as I'm not getting ripped off. Amazon was the first place I went to to make sure I knew what I was looking for
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    You might need a decent charger to repair your HV battery but you have to figure out what exactly is going on first. I can't think of any means to "trick" the ecu- all the voltages have to be even both just sitting there and under load. You can disconnect 12V power to reset the HV battery ecu but if the block voltages are really that far apart it won't try to start. You need to SAFELY disassemble the battery case and measure voltages at the modules directly. Then disconnect the HV battery ecu connectors and check for corrosion or damage to the harness.
    If block 3 and 4 are really that low compared to the others, charging probably ain't gonna help. Will likely need modules replaced, and that brings up the whole balancing the modules and having different modules throw codes again (whack a mole).
    #17 mr_guy_mann, Jan 27, 2021
