Tricking HCAC codes into going away?
Discussion in 'Generation 1 Prius Discussion' started by aiden, Jun 9, 2021.
  1. aiden
    aiden New Member
    AZ
    2002 Prius
    Hi there,
    The catalytic converter incl. the HCAC system was stolen from my 2002 Gen. 1 Prius. Installing an aftermarket cat would still cause a DTC for the HCAC valve not being able to close (P1437). I'd like to avoid having to replace the entire front exhaust assembly, so is there a way I can trick the ECU into thinking the HCAC valve is still working? I've read several posts on here about DTCs P1436 and P1437 for the HCAC valve being stuck closed or open, respectively, but the only solution I have come across seems to be from 2014 posted by user "sly caulfey". In his post he claims:
    I was wondering if anyone has tried this before or could vouch for this working? I'm thinking of trying to clamp the vacuum hose leading to the HCAC actuator shut, and seeing if that has any effect.
    Nine44 likes this.
  2. aiden
    aiden New Member
    AZ
    2002 Prius
    Hey guys,
    If anyone finds this useful, I ended up disconnecting the original vacuum hose leading to the cat, and plugging the plastic T-connector it was attached to with a piece of duct tape. It's a more simple version of the fix I mentioned in my previous post. This did get rid of the P1437 code that my Prius was showing, which was triggered because the vacuum line was previously unplugged, making the Prius think the HCAC valve was stuck open. Unsurprisingly the P1437 code was replaced by a P1436 code, meaning the Prius now thought the HCAC valve was stuck closed since the vacuum line was sealed. Luckily even with the new code, the CEL went away, so I think I might be able to pass emissions after installing an aftermarket cat, which should deal with the P0420 code I was previously getting. When I emissions tested the Prius in AZ, the only code listed as a reason for failure was the P0420 code, so my theory is the HCAC codes should not affect emissions testing if they don't turn on the CEL. The duct tape is only a temporary fix and I plan on plugging the catalytic converter end of the vacuum hose that is dangling beneath my car with something more permanent. I'll keep you guys updated on if this aftermarket cat fix works and try to post pics as well.
    Aiden
    #2 aiden, Jun 9, 2021
    Nine44 and Bruce Berquist like this.
  3. Soren Lorensen
    Soren Lorensen New Member
    Seattle, WA
    2001 Prius
    Any update on the HCAC and the CEL?
    BTW, Did you use one of the "Direct fit" aftermarket cats for gen 1 with one cat? I am wondering how well the direct fit gen 2 with 2 cats fit. I mean, I expect some welding is going to be needed, but the thieves took the HCAC assembly and the resonator, so I might as well replace both cats.
  4. nimblemotors
    nimblemotors Re Member
    117
    37
    Sacramento
    2002 Prius
    I just installed the gen2 cat in my gen1. Of course I had to fabricate all the back tubing as you get just the front two cats.
    I'm going to tackle the HCAC codes..
  5. Soren Lorensen
    Seattle, WA
    2001 Prius
    Awesome. Keep us posted about HCAC.
  6. nimblemotors
    117
    37
    Sacramento
    2002 Prius
    Well so far I can't get the code to show up on this car. I know my blue one, it showed up right away. It opens the valve when cold, and then closes it when its warmed up, I think the code showed when it warmed up. So it is not so easy to make it notice it isn't working, and so far, I have not gotten the code on the green one.
    btw, to pass smog, you can just warm up the car, clear all the codes, then drive it around until its 'ready', then have it smogged, it will not throw the code until it cold again.
  7. nimblemotors
    117
    37
    Sacramento
    2002 Prius
    So I got the P1436 with the hose plugged up. I had removed the vacuum canister from the exhaust, and plugged it into the hose,
    and the P1436 cleared. As one might expect, the sensor is only measuring the air flow in/out of the canister and not doing checking anything with the actual exhaust. So if one attaches a vacuum cannister to the hose, it should not trigger the code.
    Coming up with one now..you can buy just the cannister from Toyota for $200. I think $2 max $20 is more appropriate.
    I turbocharger waste gate control looks about the same, I have some of those around here.
    Or something else more common, thinking of a syringe in a big size or a epoxy dispensor that already has a spring in it..
  8. nimblemotors
    117
    37
    Sacramento
    2002 Prius
    Finally got it. Took about 4 tries..but the final solution that worked used a pop-up sprinkler and a balloon.
    Hose connected via a drip irrigation fitting on the threaded side of the sprinkler. Gutted the sprinkler inside,
    and kept just the spring and the spring seat, and then covered the top with a balloon (cut off necked down part),
    and secured with a zip tie. When the car turns on the valve, it sucks down the ballon and compresses the spring,
    and then when it off it returns. Over time the balloon might tear, so might need a heavier duty one than a party balloon. I bought some 'water balloons' in the past but could not find them, they are heavy duty balloons.
    So now just tuck the contraption under the hood.
    WHCSC likes this.
  9. Soren Lorensen
    Seattle, WA
    2001 Prius
    Good Work. I am guessing that attaching pretty much any vacuum actuator to the vac hose would do the trick.
  10. nimblemotors
    117
    37
    Sacramento
    2002 Prius
    What I learned was it has to have a volume that is similiar to the oem unit.
  11. ChapmanF
    19,019
    Now that's some inventiveness right there. :D
  12. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
  13. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Has anyone tried a vacuum advance unit from an older vehicle distributor. It works off manifold vacuum and has adjustable spring tension.
  14. Soren Lorensen
    Seattle, WA
    2001 Prius
    Makes sense. I got the cheapest actuator I could find off ebay, which was a used CC actuator from a Honda Goldwing. We'll see if that works.
  15. Stock808
    Stock808 Junior Member
    Hawaii
    2001 Prius
    can anybody link a cheap vacuum actuator that'll work to clear the P1436 code. I plugged up the hose near the catalytic converter P1437 disappeared but replaced with P1436 I really don't like seeing the CEL Light on
  16. Soren Lorensen
    Seattle, WA
    2001 Prius
    So the Goldwing Actuator has worked great: no check engine lights anymore.
    Search eBay for "goldwing cruise actuator gl1500" and you should currently find a bunch, starting at $7.25 shipped.
    To install in the engine compartment, see the photo I am posting and pull that hose off and put it on the actuator. That rigid line goes down and connects to the flex hose at the cat.
    Green Ste and Nine44 like this.
  17. Augustine
    Augustine New Member
    2002 Prius
    I
    I've been following this thread trying to piece the information together. I ordered the suggested valve, a summary of what you did would be much appreciated. The previous owner replaced the stolen CAT, but I don't see a valve anywhere on it (they managed to pass the smog test, I got to deal with the code now).
  18. Larry Grant
    Larry Grant New Member
    Reno, NV
    2003 Prius
    Soren,
    I'm fighting the same problem you seem to have conquered - stolen cat replaced with a Gen2 ebay cat assembly. $85 delivered. Was impressed on how well that part fit and the fact that there were no O2 codes. Apparently the aftermarket cat is doing a reasonable job.
    For the remaining P1437 and P1436 codes, I tried a beefy Borg Warner choke pull off from a carb. No dice. So would like to move to the Goldwing solution. In addition to the actuator device/assembly there is apparently a separate vacuum canister that works with the cruise control. From reading your post, it sounds like you used the actuator only and did not use the vacuum canister. Could you please confirm. Also, could you comment on how a cc actuator might operate differently than a choke pull off diaphram.
    I thank you in advance.
    Larry
  19. Soren Lorensen
    Seattle, WA
    2001 Prius
    Most likely you don't see a valve because its not there. Unless the previous owner replaced the whole cat assembly with a genuine OEM Toyota one, in which case, you wouldn't have any code issues.
    What to do: Pull the hose with the red arrow in the pics above off the rigid line that goes back and down toward the cat, and put it on the barbed end of the Goldwing actuator (you may have to pull a piece of old hose with a braided exterior off first). Done. lay the actuator assembly in that gap to the left of the engine, close the hood, drink a beer.
    Nine44 likes this.
  20. Soren Lorensen
    Seattle, WA
    2001 Prius
    Yes, Actuator only and not vacuum canister.
    I know nothing about the choke diaphragm you tried, but Nimblemotors hypothesized that the actuator "has to have a volume that is similar to the oem unit" to trick the sensor into believing that the line is connected to the original type of HCAC actuator. I suspect the unit you tried may have been too large.
