Trickle Chargers and "Battery Mainainers" not the same thing
Discussion in 'Gen 3 Prius Main Forum' started by ES44AC, May 11, 2012.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    Hello,
    I see the term trickle charger being used quite often and there is a difference between that item and a battery maintainer. Years ago trickle chargers were all we had, but left un-attended they would boil a battery dry, because they were un-regulated in how they charged.
    Today's modern battery maintainers bring the batter up to a full charge and then cut back on charging voltage and current since there is no need for it at that point. They will start to charge only when needed and can be left on for long periods of time. Most of the ones I have successfully used simply plug into the cigarette lighter to charge the battery. If for some reason this isn't acceptable on a Prius please correct me.
    What we need to use is a battery maintainer for the 12v battery, definitely NOT a trickle charger.
    hope this helps
    Regards,
    ES44AC
    Maria T Hannigan likes this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am old, I will try to keep up better.
    Sezy likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Some battery maintainers can also break up sulfate crystals that form on the lead plates extending battery life. This is a good thing.
    JeffD
    ps. I'm not sure that you are older than me Jim.
  4. ETC(SS)
    7,530
    Concur!!!
    It's not all that bad though. Wal-Mart sells a battery tender for $20.
    Like the Prius...my Harley V-Rod has a very weak 12v battery. Unlike my Prius, my VRSCD battery is still going strong after 7 years, mostly b/c I semi-consistently place it on a battery tender whenever it’s not going to be in use for > a week.
    Don't be fooled into thinking that you "have" to get a $100 Gucci battery maintainer. As long as it has the built-in circuitry that prevents over charging, you'll be fine.
    I've got 2 of the $20 units. They've been in use on my motorcycles and lawn equipment for >6 years. I bought a few extra quick connect plugs and I cycle the tenders between all of my batteries whenever they need to sit for a while.
    No battery problems here.
    Robert Holt likes this.
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The 12v port in a Prius is not hot. This is why you can't use it to recharge a device while the car sits overnight.
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The "Battery Tender" comes with two "pigtail" leads, one with clips and one with ring terminals. I installed the one with ring terminals on the "boost terminal" in the engine compartment fuse box and use the other one on the FJ Cruiser. I haven't really needed to use it on either vehicle, but it's cheap insurance when I know one of the two will be sitting for awhile. It helps to have a garage to park in an plug it in to. ;)
  7. edwardob
    edwardob Member
    227
    33
    ireland
    i bought a liitle 12v solar charger which i stuck to rear window with wires permenently attached to battery
    it's output is very small but keeps it charged when i'm away for a month
    i leave it in all year round
  8. Flying White Dutchman
    4,376
    313
    a good trickle charger will stop at 13,5 volts
    but i agree there are a lot of stupid chargers out there and they will boil it up.
    i use a smart charger that even got a anti sulvation setting
    this charger really stops charging and lets the battery voltage drop a bit below 13,5 volts
    its the Ctek MXS 5.0 i recommend it
    using it for less then 1 year now but i hope it will extent the lifespan of my 12 volt battery
    its charged every night and the compleet weekend when car is parked at home
  9. chrisD
    chrisD New Member
    Hi edwardob, I've been looking for a battery solution for a 2010 Prius and I think you've got the answer. Can you point me in the right direction to setup the same system? Which model solar charger did you get and where did you purchase it from?
    Also just to clarify, this is for charging the small 12V battery, correct? In my 2010, the 12V battery is under the hood in the front of the vehicle. How does your solar panel connect from the rear window to under the hood?
    Thank you sir!
  10. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  11. edwardob
    edwardob Member
    227
    33
    ireland
    all prius battery 12v are in rear????? sure it's a prius?
    got mine on ebay....just attached to battery...and stuck solar panel on rear window with stick pads...
  12. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    what kind of car do you have ... not a prius if you have 12V battery under the hood :) can you send us a picture of the battery under the hood ???
  13. chrisD
    chrisD New Member
    I have a Prius 2010, this is not a picture of my car but its the same configuration. I have circled what I thought was the 12V battery: https://dl.dropbox.com/u/7646006/prius2010.jpg
    Is this not the 12V? Under that black cover there is the positive battery lead which I have used to jump the car.
  14. edwardob
    edwardob Member
    227
    33
    ireland
    no battery is in rear on right hand side
    take out your rear tray /cover till you see your spare tyre
    look in the right hand side just in front of light..there is another piece plastic...remove
    euraka!!1 there's your battery
  15. chrisD
    chrisD New Member
    Thanks, what are the specs on your solar panel? Max Watts/mAmps? Does it have any kind of "smart charging" feature or just something like this: 7-Watt Solar Charger - 12v Battery Charger
  16. edwardob
    edwardob Member
    227
    33
    ireland
    long since lost the box..don't know spec
    just keeps battery topped up when i go away for a month
    just make sure it has some form regulator stop overcharge
    plenty on ebay...just search
  17. szgabor
    994
    175
    Oceanside NY
    NOPE that is the fuse box ... and where you actually have the jump port .... I am again stumped that somone spend 25k on a car which is non-traditional and do not even read the manual (the short version)
  18. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    You are correct, even all battery maintainers are not the same. Some can only be used on a flooded cell battery, but not on an AGM battery like the 12V in a Prius.
    In my 2010 Prius, I have a permently mounted Battery charger/ maintainer/ desulfator, wired directly to the 12v battery. In winter, I may not drive the Prius for a month or more. If the car has / will be parked unused for more than 2 weeks, I plug in the Maintainer.
    The one I use is safe for an AGM battery. It is a BatteryMINDer brand, sold through Northern tool.
    I have 4 of this model, that I rotate monthly through my fleet of farm equippment in the off serason.
    A majority of my equippment have Optima or Exide Orbital , spiral cell AGM batteries.
    BatteryMINDer Charger/Maintainer/Desulfator System — Model# 1500 | Battery Maintainers| Northern Tool + Equipment
  19. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    do not buy the $5 battery maintainer at harbor freight, it fried my battery .
  20. stonerider
    stonerider Member
    107
    Lompoc, CA
    I went and bought the $10 battery maintainer at harbor freight this morning. Surely, spending double meant I got the better product???
