Trickle Chargers and "Battery Mainainers" not the same thing
Discussion in 'Gen 3 Prius Main Forum' started by ES44AC, May 11, 2012.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    If that is the one with TWO plastic boxes attached to the cords, then yes maybe.
    I have heard a lot of car and motorcycle owners claim that they work just fine for long term use but I remain somewhat skeptical.
    For one thing, they contain no "diagnostic" lights to tell you what is going on.
    I prefer to throw another $15 in and get one with lights and a known brand name.
    I would be interested to hear what the "float" voltage is after the HF one has been connected for a few days.
  2. qdllc
    qdllc Senior Member
    1,377
    400
    Fixed It For You.
    I call "Harbor Freight" catalogs "HAZARD FRAUGHT" catalogs.
    It's all cheap garbage...mostly from China. Good for the once-in-a-blue-moon need, but not something you want to rely on regularly.
    UNLESS it is made by a major name manufacturer and HF just happened to get some in stock, I'd not trust it with anything important.
    Heck, I bought a catalytic heater at Wal-Mart from Coleman for camping. It went wonky on a trip, and I had to replace it with an identical unit from a outdoorsman store. Same thing, but made much better. Because Wal-Mart demands low-ball prices, many big name providers make a cheaper version of their products for Wal-Mart compared to what goes to other retailers.
  3. qdllc
    qdllc Senior Member
    1,377
    400
    Also, while there is a difference between a "trickle charger" and a "battery maintainer," most any QUALITY unit does "speed charge," "trickle charge" and "maintain". You may need to set a switch for "speed" vs. "trickle" charging, but once a full charge is registered, the unit goes into "maintenance" without further prompting.
    It's well worth-it to buy a quality unit that does it all.
  4. Easy Rider 2
    1,584
    258
    Ocala, FL
    Your opinion.
    I think if you keep in mind that the quality might not be the best, you can get some really good deals.
    I have a free flashlight or two and a free multi-meter that work just fine; well worth what I paid. :)
    I also have an infared temperature gun that works good too; for about $25.
    DoubleDAZ likes this.
  5. qdllc
    qdllc Senior Member
    1,377
    400
    Fair enough. I'd not trust tools you can't afford to have break in the middle of a job or jack stands not made by a reputable maker, though.
