Trickle charging in cold
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by estarlin, Sep 2, 2019.
  1. estarlin
    estarlin New Member
    American Midwest
    First winter in my recently purchased 2007 Prius. I live in Iowa, so winters can get pretty harsh at times. Is there any reason/benefit to keeping the 12v battery on a trickle charge when temperatures get low? What about the HV battery? The car is driven daily for multiple short trips, usually under 10 miles. Sorry if this question has already been asked, but there are so many to search through.
    Thanks all
    Eric
  2. JC91006
    16,939
    8,647
    I would only recommend you replace that 12v battery every 5 years so you won't run into it dying in the cold winter months. So check the date, if it's over 5 years old, get another one and you won't have to worry about trickle charging
    frodoz737 likes this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I say couldn’t hurt. Make sure you have a charger that works with AGM batteries. It doesn’t need to be super powerful either. Max charge on a 2nd gen Prius is under 4 amps.
    52,891
    welcome!
    hybrid battery is fine.
    in your shoes, i would poly use a maintainer just in case you don't drive it for awhile. it really depends on the 12v battery age, condition and usage. but it is a weak spot in the prius.
    you may also want to consider a block heater, and remember, the jump point for the 12v is in the fuse box under the hood
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I would keep a 12 volt battery tender on it if hardly driven at all like your doing. Short trips only are hard on everything in a Prius especially the 12 volt battery. 10 miles in the winter is hardly even warming the car up.
    Plus that’s really hard on the hybrid battery.
    Get a good quality voltmeter and get acquainted with measuring the dc battery voltage at the front jump points to keep an eye on it you do not want to be stranded with a dead 12 volt hilarity sometimes happens to your wallet there.
    Never attach anything directly to the battery in the trunk, use the front underhood jump point only.
    That’s what it’s there for.
    If hardly driven like your doing in the winter I would once in a while put the car in inspection mode and let the engine run for A while. Use high quality engine oil.
    Go on YouTube search PRIUS INSPECTION it will give you the steps to put the car in inspection mode lets the engine runs endlessly.
    Bottom line a G2 Prius does not do well with short drive life. Car needs to run long enough to charge both battery’s.
    And lastly hardly ever using the ac is death for that system. Try to run the ac once in a while in the winter.
    Skibob likes this.
