tricks for a door that won't close
Discussion in 'Gen 3 Prius Main Forum' started by marlyn, Jun 5, 2023.
  1. marlyn
    marlyn New Member
    Washington DC
    My driver's side door on my 2010 (140k miles) was just clipped by a speeding pick-up. It will need a new door frame, which sadly means the car is totaled. In the meantime, the door won't shut all of the way, I just had it jumped because the battery died overnight. I turned off the dome light, any other tricks or ideas so it doesn't keep dying while I try to figure out what to do with it?
  2. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    A decent body shop can fix a bent door frame... As long as air bags weren't deployed, it's not totaled... As for 12v drain, In the door frame you'll find a pin switch that needs to be pushed in or disconnected to turn door open light off on dash.
    Johnny Cakes and ColoradoBoo like this.
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Removing the door sill light is easy. Since I stealth camp, did that so that there is no light when the door is open.
    Would the door open light on the dash be enough to discharge the battery overnight? Or is it it a matter of keeping the computer active that drains battery?
  4. fuzzy1
    10,690
    The dashboard LED itself is minimal. But based on previous threads, it seems that the other electronics that are kept awake by the door switch, are significant. So the door switch needs to be tricked or altered into thinking the door is fully closed.
    Johnny Cakes likes this.
  5. Mendel Leisk
    42,293
    Might be able to tape the door switch to stay down (indicating closed). They’re pretty strong though. Or put a spring clamp on it?
