Tried installing the OCC... no room!...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NutzAboutBolts, Aug 30, 2017.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    KISS!? :eek:Got ya
  2. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Yes definitely...
    OCC was a great "catch" on your part,
    no pun intended!
  3. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Just vacuum pressure drawn in by the throttle body. I have seen occ made out of energy drink cans.
    Robert Holt likes this.
  4. Mendel Leisk
    42,376
    So mostly vacuum, hmm. I've got six airplane clamps, three per line: basically two per splice barb and one at the OCC barb. The once or twice I've tried to pull a hose off a barb, I've been thinking those clamps really aren't need. Oh well, it's tight, lol.
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    rather safe than sorry/
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Why do I keep getting this, whenever I want to post a video here?
    Please can some help?
  7. Mendel Leisk
    42,376
    Can you convert it to an acceptable format? Handbrake is good for that.
    Prodigyplace likes this.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Convert it to an mp4 file if possible.
  9. CR94
    CR94 Senior Member
    2,839
    1,244
    Northwestern S.C.
    Yes, as mentioned a few days ago. Those hoses will not slip off unless very loose, or something yanks on them.
  10. Mendel Leisk
    42,376
    You practically have to destroy the hose to pull it off with those barb connectors. Designed as one use I guess.
  11. working1
    working1 Active Member
    121
    112
    Update on the OCC install after 13K miles. The epoxy bonded bracket mounted to the lower cross member is working out fine. It has survived a cold Wisconsin winter with no issues. Car was jacked up multiple times and any cross member deflection has had no impact on the bracket bond. One change made is routing the drain line valve to a more accessible location. The valve was originally installed where it could be reached by opening the oil change panel. Due to the high amount of condensation being collected, frequent draining is needed. Suspect this is less of an issue during warmer weather. Pics below show new valve location.
