Trim 5 headlights on Trim 2
Discussion in 'Gen 3 Prius Technical Discussion' started by Ken Huang, Feb 12, 2022.
  1. Ken Huang
    Ken Huang New Member
    Los Angles
    Hi All I like the Trim 5 headlights very much the one that has 2 projectors and a reflector combined, compare to the ones on most Prius which is just a projector and a reflector. I was wondering if I get one of the Trim 5 headlights and it would fit into trim 2’s head light housing and would it work or not
    Thank you
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,694
    395
    2013 Prius Plug-in
  3. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
  4. CivicSky
    CivicSky Member
    163
    71
    San Deigo
    Would you reconsider your headlights option after seeing those JDM ones from a Prius G?
  5. ChapmanF
    17,326
    Hadn't seen those before. What makes the light in those?
  6. xliderider
    8,055
    3,222
    Honolulu, HI
    HID, and they're for right hand drive Japan market, so the cutoff is wrong.
  7. CivicSky
    CivicSky Member
    163
    71
    San Deigo
    I know and they are also illegel for the missing amber reflectors on the side. The low beam can easily be re-aimmed up/down & left/right which I did in an evening.
