Trip A and B odomerters keep resetting to zero as well as clock 2008 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Greg Kaiser, Nov 12, 2014.
  1. Greg Kaiser
    Greg Kaiser Junior Member
    33
    Santan Valley Arizona
    Hi
    I have a 2008 prius and the Trip A and B odomerters keep resetting to zero as well as the clock to a different time. It has happened 3 times in the last month.
    I stopped to ask a seasoned service if he knew what the problem might be and said that he had never heard
    of it. I recently 3 mos ago replaced the 12v ignition battery.
    Any ideas.
    Thanks
    Greg
  2. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Maybe you got a bad battery. Try checking the voltage of the 12 volt battery with a multimeter or using the 12V check method here in the forums, I don't have a link here from my phone but try searching for 12V test method and it should lead you to it.
    LG-AS780 ? 2
  3. valde3
    valde3 Senior Member
    2,002
    746
    Finland
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Also, check the tightness of the connections including the bolt to the chassis on the negative lead.
  5. bisco
    51,155
    gen II had trip a and b? i think i'm getting alzheimers.:confused:
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    String Universe Theory.
    You sure you aren't simply phasing in and out of numerous different possible states of existence?
    Do your shoes change? Like you are wearing sneakers....then step into your Prius and suddenly they are Hush Puppies?
    Try to take note of what color the sky is, and/or how many moons are in the sky.
    This may not be a warranty issue.
  7. alekska
    alekska Active Member
    435
    138
    Atl
    Idea # 1 - bad 12v battery OR connectors not tight
    Idea #2 - bad contact at fuse that supplies 12v to clock.
    - Alex
  8. GregP507
    GregP507 Senior Member
    3,002
    481
    Power-interruption would be my first guess.
  9. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
  10. Greg Kaiser
    33
    Thanks for all the replies. The 12v Battery hot lead was loose.
    alekska likes this.
