Trip and Display buttons won't work
Discussion in 'Gen 3 Prius Technical Discussion' started by xamza, Apr 25, 2019.
  1. xamza
    xamza New Member
    16
    lahore
    ,I have a 2012 Prius. My trip and display buttons on my steering wheel will not work. The rest of the steering wheel buttons work (temperature, volume, changing radio station up/down). I check with scan tool and getting B1504(lost communication with steering SW) Does anyone have any advice to get them working again?
    52,630
    it is usually the spiral cable. try the buttons as you turn the wheel from lock to lock.
  3. xamza
    xamza New Member
    16
    lahore
    I also replace the spiral cable but still the issue is same...:/
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Where’d you get the replacement cable and how much was it?
  5. xamza
    xamza New Member
    16
    lahore
    From local supplier
  6. bisco
    52,630
    some chinese cables are bad out of the box. it looks like you'll have to do some electrical testing of the switch, cable and receiver at the other end. ecu? the service manual might be the place to start
  7. xamza
    xamza New Member
    16
    lahore
    Thanks bisco for the replay. unfortunately I also tried to change the whole steering but still the same issue only trip and disp not working. IS there any fuse of that? because when i remove the battery and reattach the battery i get the other screen display only once.
    So what i confused is is there any fuse of that thing or its issue in the ecu or something?
  8. bisco
    52,630
    idk if there is a specific fuse for that button. maybe it is the ecu then, or the connections
  9. alexk345
    alexk345 Junior Member
    46
    india
    I have same problem . It either happened after oil change or battery jump
    First oil change happened. Left the car idle for 2 week. Then did battery jump.
    Then i noticed display button dont work.
  10. etherdog
    etherdog New Member
    Indiana
    I have the same problem with the TRIP/DISPLAY buttons. My dealership didn't seem to have any familiarity with the problem, but the clues you people are leaving are helpful as to what the problem is not. Thanks!
  11. Fantasticpow
    Fantasticpow New Member
    Im currently having the same issue, after some research, the spring clock is defected and needs a replacement.
    Another situation involves a car coming with an aftermarket radio system. Where you have to ground the pink wire.
  12. andreimontreal
    andreimontreal Active Member
    390
    118
    40
    Montreal
    Could it be the buttons themselves? I don't know what the electronics looks like in the wheel, but I wonder if there is a way if you can test if the circuit is closing as you depress either button/s.
  13. ChapmanF
    18,830
    The electronics in the wheel will be different depending on whether the car has or does not have the "Touch Tracer" feature (where the button you're about to press shows up in a purple outline over the speed / fuel display). Threads about that have the details.
    andreimontreal likes this.
