Triple A aux batteries
Discussion in 'Gen 2 Prius Main Forum' started by Berch1943, May 15, 2021.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,108
    6,969
    Texas Hill Country
    It is better to use a $25 battery maintainer on the car rather than attempting to drive it a hour each week if there is no other reason. The car is always draining the battery when off, its called parasitic draw. It should be 15ma-30ma, easily measured by a mechanic or handy diy'er. If higher, say 90ma-900ma or more, the cause should be found and resolved, a more advanced task.
    The brake actuator is failing. Get it fixed. Not cheap.
    Battery Maintainer
    Parasitic Draw
    #21 rjparker, May 16, 2021
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    And stop connecting your charge leads right to the battery use the front jump point that's what its for.
    Check the DC voltage on the front jump point. A happy Prius battery lives around 12.6 volts. Easy way to check how bad your battery is with the car OFF turn on the headlights on high beam. What does the battery voltage measure at the front jump point with that load on it?
  3. Berch1943
    Berch1943 Member
    146
    Arizona
    Yeah I think it's because i have a failing brake pump , I hear it constantly and that drains the battery. I read horror stories that somebody's brakes failed on a freeway and almost got into an accident. A dealer would probably quote $3000 to fix it, I don't think it's worth it.
    52,857
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Nobody knows the first answer because it varies WIDELY depending on the age of the battery and on what kind of power draw you have from accesssories.......and on how long it sits BETWEEN trips.......and on how HOT the environment is.
    My wild guess: 50 miles a week.
    And yes, it might explain the action of the brake "actuator".......or it might not.
    You will see when you get a good, fully charged battery in it.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    To prevent a bad crash on the freeway ?? I don't follow that logic.......or lack of.
    And your wild guess on the cost might be WAY off.
    It could be a loose fitting.
    And a new pump might be a lot less than that.
    Best to KNOW and not to guess.
