Trod abut No codes....
Discussion in 'Generation 1 Prius Discussion' started by JamesGilmore, Dec 11, 2019.
  1. JamesGilmore
    JamesGilmore Junior Member
    palmdale ca
    2002 Prius
    I
    If i Am getting the traingle of death but no codes and NO check engine light would you assume it to be a NON-engine problem ?
    I have a scan gauge 11 and see no codes. going to try and get a blutooth adapter and the other stuff bbecause I have a netbook I should be able to put tech stream on...
    52,348
    you probably need tech stream
    jerrymildred and mroberds like this.
  3. mroberds
    mroberds Member
    143
    58
    2001 Prius
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I would assume that the code reader isn't capable of reading Prius proprietary codes.
