Trouble codes 0441 and 0445
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mike Jossa, Sep 16, 2019.
  1. Mike Jossa
    Mike Jossa New Member
    Lago Vista, tx
    Can’t seem to find the cause of these codes. Had the fuel tank (which I had replaced) and evap system smoke tested. No leaks. Replaced both control valves/ solenoids in purge system. Replaced vacuum pressure canister and pressure sensor. Vacuum tested line to carburetor. It held.
    What have I missed?
    P.S. Just completed a road trip of 4300 miles with no problems and got approximately 42 mpg.
    Should I be concerned?
    52,854
    are those prius codes? what reader are you using?
  3. Mike Jossa
    Lago Vista, tx
    No. They are standard OBDII codes. 0441 is “incorrect purge system flow”.
    The other indicates a large leak in the outrage system.
  4. Mike Jossa
    Lago Vista, tx
    that’s purge system.
  5. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    They are actually P0441 and P0445, which is why bisco is asking, because without the letter (which indicates the system), they look odd.
    Diagnosis of these two codes is pretty involved, and I suggest taking a 2 day subscription at Technical Information System (TIS) and reading up on them.
    Skibob likes this.
