Trouble Codes you never want to see
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tempus, Feb 20, 2006.
  1. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    it is a diode. it's used as an amplifier.
    the problem is due to a weak signal in the cell voltage monitoring circuit. it will read 0 volts in all cells no matter what the actual charge. all this does is boost the signal with the actual voltage so the system knows what the actual voltage is.
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I stopped in a local dealership's parts desk today and asked to see
    the widget in question, part number 82163-47180. The guy looked
    and said they don't stock it, and he even checked if their particular
    dealership had *ever* ordered one. Answer: no. So they've never
    done EG023-04 at this dealership, evidently. If I wanted to pay
    $34 or whatever I could have ordered one to dissect, but my VIN is
    past the threshold so I don't actually need it. Maybe next time
    I'm in the battery box I'll look for it, but it wouldn't surprise
    me if in later cars it's done as an internal improvement in the
    ECU itself.
    I'm at a loss to understand how a diode is used as an "amplifier",
    by the way... remember, whatever the device is gets connected
    ACROSS the 12V power and ground leads to the ECU. That's usually
    the job of a decoupling cap, although I could believe a reverse
    diode to prevent the power rail from going negative during power-off
    conditions, pushed there by random HV battery voltages from the
    sense leads and the fact that the HV battery floats independent of
    the car's ground. A transient coming out of that state at the next
    power-up could conceivably confuse the ECU for a while, unless the
    +12 is held close to ground level in the meantime.
    There's gotta be a real engineered answer to this.
    _H*
