Trouble getting oil filter off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BradC, Jun 11, 2017.
  1. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    It is easy on the Prius. You just have to get this cap loose. Trust me. Even with my other cars, the oil change shop or dealership mechanic always overtorqued the filter. Its like they want you to have to take it to them to get it off. Bought my car new. First oil change was a nightmare as it was extremely tight. Jacking the car up high enough to get the proper leverage with a breaker bar and using all my body weight finally got it off. Since then, it takes less that 10 minutes to do my oil change and the cap comes off easily.
    BradC likes this.
  2. BradC
    BradC Member
    42
    25
    Good to know. I will be doing another oil change tomorrow. I bought a breaker bar at Harbor Freight and will hopefully be able to get the cap loose this time. ::fingers crossed::
    Raytheeagle and jerrymildred like this.
  3. Mendel Leisk
    42,237
    Have you got the Honda oil filter socket? It's been working fine for me, same size. I suspect those slots that go around the stiffeners are not doing much. Never had any problems, but then again, the only people to torque it besides me were factory personnel in Japan. This is my set up. Again, the long lever arm, and a very snug fitting socket, are key:
    ^ ol' resistance is futile
    #23 Mendel Leisk, Jul 22, 2017
    Montgomery and NutzAboutBolts like this.
  4. BradC
    BradC Member
    42
    25
    Yes. I use the more expensive Fram filters that have a grip on the end, so I've been able to hand tighten and hand loosen filters on our Odyssey for years. Last time, it was a bit tighter than usual, so I used the socket, but it came off without a problem when I did so.
  5. Barnesie
    Barnesie Junior Member
    Phoenix
    Get this :
    And as others have get a breaker bar and you will be good
  6. Mendel Leisk
    42,237
    If you're dealing with over torque, a possible tactic:
    Start with good quality, heavy gauge, tight fitting socket. Wet the inside, dust it with pumice (fine grit), push it onto the housing (it may need gentle hammer taps).
    This I think will dispel any chance of the socket slipping, rounding the corners.
    BradC likes this.
  7. BradC
    BradC Member
    42
    25
    I have the Motvix socket, and I bought a breaker bar yesterday.
  8. BradC
    BradC Member
    42
    25
    Failed to get the stupid oil filter cover off. Managed to break one of the tabs on the cover in the process. Ugh.
    I'll have someone else do the oil change this time. I assume the cost to replace the oil filter cover won't be a lot.
    I'll try again next time. Hopefully they won't over-tighten it.
    Mendel Leisk and Raytheeagle like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Toyota Vallejo on Sundays offers $10 off any service over $30. Guess how much an oil change is;).
    So for $20 if you bring your own oil, you could have this done.
    You can also watch them change the oil from the comfort of the waiting room which is opposite the oil change bay:). Might have to see about getting an appointment though as they get busy on Sundays.
    One place to consider(y).
  10. BradC
    BradC Member
    42
    25
    Vallejo is way too far from me. I'm just going to have the guys who come to my work do it when I'm in the Bay Area this week.
    Do many places let you bring your own oil and filter and then knock down the price?
    Raytheeagle likes this.
  11. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Toyota Vallejo does. You can call and ask others.
    Might be worth posting the results of what you find sonothers can know(y).
  12. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    I have noticed the cap to be much tighter when taking off than when putting on. Also, When putting back on with the new O-ring, it always spins on easily till it seats and takes about a quarter turn with a wrench to get tight. On removal, like I said it is much tighter requiring some force and also has a good amount of friction for a couple of turns. My thought has been that the new o ring swells a bit after installation.
    BradC and Mendel Leisk like this.
  13. Mendel Leisk
    42,237
    Same observation here: a fair bit of friction when turning, until the O-ring is free of the barrel. Instruction says to oil the O-ring at install, with fresh oil; guess that's kind of baked off by the next oil change.
    BradC likes this.
  14. BradC
    BradC Member
    42
    25
    Had the guys who come to my work do the oil change, using my oil and filter. They replaced the broken filter cap for $44.99 and were supposed to charge me $29.99 for labor to do the oil change but ended up waiving that because they were under the car to replace the filter cap anyway. I appreciated that.
    Happy to do so, but it looks like these guys don't have their own shop - they visit different companies throughout the Bay Area and do onsite servicing. FWIW, though, if anyone is curious, here's their site:
    More Automotive Group | Car Care
    Good to know for next time when I try the DIY approach again. Thanks!
    Rebound and Raytheeagle like this.
  15. stanrich
    stanrich New Member
    Anaheim CA
    Had all the right tools and still was unable to remove cap until I jacked the car up enough to get better leverage from 24inch breaker bar.
  16. Mendel Leisk
    42,237
    I find it a cakewalk with an 18", but that's when the only people to put it on were the factory mechanics (who are very likely doing it to the specified (18 foot pound torque), and me (same story). I have a hunch many of these "pro" mechanics are using high powered battery powered impact wrenches.
  17. ASRDogman
    ASRDogman Senior Member
    8,018
    4,071
    Just did my 3rd oil/filter change on my 2010 and it's a lot easier if you remove the metal clip that I guess
    is supposed to lock the filter housing in place so it does work it's way loose.
    The filter wrench is "supposed" to move it out of the way, but it's a pain to do, unless you have a lift. :)
    I've tightened it just snugly and put the clip back in. The first oil change I had the clip in and turned it by
    hand until I had to use the wrench, but just till the clip clicked into place. No leaks.
  18. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Actually, go to that page, tab down, same thing for 9.99$
  19. Montgomery
    2,254
    2,242
    Orange County, CA
    I had to laugh when I saw this updated thread. This issue is as old as Methuselah (that means really old). I love seeing the latest ways some of us have found getting the oil filter off. The first time is the hardest. I broke a tooth on mine, but since then, it has been pretty easy. Keep up the good post about this.
    Raytheeagle and Mendel Leisk like this.
  20. Mendel Leisk
    42,237
    Isn't there a song about that? Yeah it's pretty much for sure those "pros" with impact guns...
