Trouble resetting check engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dbasra99, Mar 5, 2022.
  1. Dbasra99
    Dbasra99 Junior Member
    32
    Parkersburg WV
    I just replaced my EGR and cooler and intake manifold. However, I have tried a number of methods and cannot reset the check engine light for even one second. I have tried the battery and a cheap scan device.
    Any suggestions?
    Thanks.
  2. JC91006
    16,827
    8,600
    What made you think the cause of the check engine light are related to the parts you replaced? Do you have any codes?
  3. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    check for unplugged connectors (especially maf, map) /
  4. ChapmanF
    18,536
    If it's called a "scan device" and not just a "clear device", then it can probably be used to find out what trouble codes you have. What are they?
  5. Dbasra99
    32
    Parkersburg WV
    Thanks for the suggestion. I think I pulled a wire when disconnecting the MAP sensor connector. Just need to get a pigtail to fix it.
  6. Dbasra99
    32
    Parkersburg WV
    Just an update. I was able to shove in a wire to the connector and attach to the broken wire and was able clear the error code.
