Trouble with power outlets
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dallasclem, May 24, 2016.
Tags:
  1. dallasclem
    dallasclem New Member
    Lake Forest CA
    I have just bought my second Prius--a used 2013 Prius 2--and when I got home from the dealership last night I moved some things over from other car, including a GPS unit that I plug in to the power outlet. Although I tried many times to plug it in--thinking the problem may be just the "fit"--I cannot get any power, from either one of the outlets--the one under the dash and the one in the box between the front seats. I tried a second plug--this one for a phone charger--and that did not work either. I tried the USB port, and it works fine. My understanding is that the two outlets are on different fuses, and I'm guessing the USB port is too, so I'm wondering if any one has any suggestions. The paperwork from the dealership says they inspected the outlets yesterday and they were working. Thanks in advance--
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    You might need to test the power outlets with a voltmeter.
  3. dallasclem
    Lake Forest CA
    Yes, thanks, most likely I'll take it back to the dealer and have them do that. Since they put a check mark next to the box that says they did that yesterday before I drove it off the lot, I was hoping there might be some other explanation! (That's not a great sign...)
  4. qdllc
    qdllc Senior Member
    1,377
    400
    Check your power adapter. 12v plugs have fuses in them. Rare for them to blow, but it can happen. It's also possible the power adapter isn't making good contact with the bottom of the socket. I had that issue with something before...very frustrating. As others have said, I would verify with a multimeter that there's power when the car is on. I have a 3rd Gen, and they are only powered when the car is on.
  5. dallasclem
    Lake Forest CA
    Yes, thanks. Both power adapters work fine in my 2006 Prius. I think you may be right about the contact though--I mean, isn't it odd that neither of two cords work in either one of the outlets? If there is a problem that a voltmeter might find in one of the outlets, is it likely that the same problem would duplicate in the other one? Maybe I don't understand how these things work but that seems odd to me (plus, I'd like to trust that the dealer really did check it out yesterday), so I'm still assuming it's something I'm doing...but plugging an adapter into an outlet is kind of hard to do "wrong", too.....
  6. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I had a plug on something (no longer remember what) that didn't make contact with the bottom of the outlet, so it is possible. I had another one where the pin got stuck so it also wouldn't make contact.
  7. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    It's easier to just check the boxes than actually test the socket. Maybe that's what happened?
  8. dallasclem
    Lake Forest CA
    Yes, that's apparently what happened. Thanks all, for the help. I took it back to the dealer and they replaced the fuse (fuses?) and now everything works fine.
  9. mrbigh
    3,686
    699
    Long Island, NY
    Make sure that the 12V sockets are free of any debris like a piece of tissue paper or candy plastic wrapper.
    The dealer may check for fuse integrity.
