Troubled rearview mirror
Discussion in 'Gen 3 Prius Main Forum' started by james nancy, Sep 12, 2021.
  1. james nancy
    james nancy Member
    110
    24
    suva,fiji
    The rearview mirror of my car will be retracted when the car is locked. I checked the switch panel and did not find the switch to turn it off, and I found that other cars do not have this phenomenon. Can this be turned off? I think that frequent withdrawals will fail one day in the future.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Do you mean the side mirrors? The rearview mirror is in the middle of the windshield and I can't imagine it retracting.
    In any case, AFAIK, only the Japanese market cars get the nice stuff. Automatic side mirror folding is mostly on luxury cars. If you check the owner's manual, I expect that it will list that feature as either not something you can change or only a dealer can change it.
    If it can't be changed, I'm pretty sure the motors can be unplugged.
  3. ChapmanF
    19,038
    I've also heard of people buying the JDM folding mirrors and installing them as a mod.
    I don't know if the original JDM cars have switches to enable/disable the folding, but I suppose it's possible somebody might install the mirrors as a mod and maybe not install every other part of the system.
  4. james nancy
    james nancy Member
    110
    24
    suva,fiji
    This car is indeed a second-hand car imported from Japan. Other feelings including fuel consumption are not problematic, but I am worried that repeated folding of the side mirrors will affect the life. There is a switch inside, but turning it on is worse. He can retract the side mirrors while driving. Don't understand why this switch is designed
  5. jerrymildred
    11,517
    14,170
    Tampa, FL
    Many cars have automatic folding side mirrors. I have not heard of them being any more of a problem than other motorized items in the car. As I said before, you can probably unplug them. But then you might not be able to fold them manually when you need to.
    james nancy likes this.
  6. james nancy
    james nancy Member
    110
    24
    suva,fiji
    Thank you for your reply, let it be like this, I don't want to lose the folding function, sometimes the parking lot is crowded
    jerrymildred likes this.
  7. MegaMix
    MegaMix New Member
    Oregon
    What do you mean by retracted? Like it automatically turns itself in a different direction?
  8. james nancy
    james nancy Member
    110
    24
    suva,fiji
    It is the side mirror folded to make it close to the front window glass.
