Troubles after changing 12v Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by docproteus, Aug 20, 2015.
  1. bisco
    52,668
    is it possible you drained the battery by leaving a light on or not driving the car for awhile?
    C1241 is low battery voltage.
    B1421 is inconsequential.
    B1801 seems to be the clock spring or air bag related.
    if it were me, i would buy a good charger (they are around $70.) and always worth having, and try charging it up, and then monitoring it, before spending $200. on a new one. perhaps you have a a drain on the battery.
    #21 bisco, Aug 21, 2015
  2. Mendel Leisk
    42,164
  3. JC91006
    16,909
    8,631
    Simple solution, return the dead optima for a new one that's not dead....or get a refund and buy a Toyota battery.
    After installing your new battery, all your troubles should go away
  4. Patrick Wong
    18,210
    6,516
    1. You could try charging the existing battery to see if it holds a charge, and if not, then return it for a warranty replacement.
    2. To answer your question, you need to use a voltmeter to measure voltage across the 12V battery when the Prius is READY. If the voltage reading is ~13.8V then there is nothing wrong with the DC/DC converter which provides power to the 12V bus and charges the battery. (There is no alternator.)
  5. docproteus
    docproteus Junior Member
    43
    Ct
    Thanks for all the great info and suggestions. I change out the battery and now we will have to see. As for the Optima I'm guessing a refund will be a fight but we shall see. I'm not positive about battery drain (light on etc) as a friend has been using the car while I've been away. It is possible but they are pretty savvy drivers and this apparently happened more than a few times so I'm inclined to think the battery is bad. Hopefully moving forward this will fix all and if not, we shall see what the next step is.
    Mendel Leisk and bisco like this.
  6. bisco
    52,668
    all the best!(y)
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Why expect a warranty claim to be a fight?
    If the battery doesn't hold a charge and it is within the warranty period it should be replaced without a fight. When my Toyota battery crapped out within 6 weeks the Service Writer started with the "out of warranty story". His tuned changed when I told him I bought the battery there less than two months ago.
    Fights tend to happen when parts are returned that aren't defective or the buyer expects something beyond the remedy specified in the warranty.
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Do yourself a favor and get a good 12V, AGM compatible, battery charger. If you had this useful tool, you would have been able to charge the battery in question, and immediately determine if it is bad or not. The automatic charger would charge it and turn off, or indicate that it could not charge the battery (defective). If the charge was successful, and the battery just won't hold the charge, its defective, assuming no excessive current draw when the car is OFF.
    Consider getting one of these two chargers:
  9. Patrick Wong
    18,210
    6,516
    OP says he wants a refund, not a replacement battery - since he probably doesn't need an extra battery gathering dust on his garage floor. That will be a fight.
    Absolutely.
  10. Mendel Leisk
    42,164
    To go with the smart charger, a digital multimeter. Any home owner, any car owner, anyone who uses ANY kind of batteries, should have one. Hell, they should be issued at birth.
