troubleshoot dash warning lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TimCom, Nov 5, 2018.
  1. TimCom
    TimCom New Member
    san diego
    2008 prius. I have red triangle, exclam in circle, VSC, and check engine. Car runs/drives fine. Research points to inverter pump. I can hear and feel it running now, but couldn't earlier. Should it run constantly? if it's the one directly behind left headlight. There's another pump in back of radiator near that one, too? I see turbulence in pink fluid in resv in top center of engine. Is it level sensitive? I see no float sensor and the difference between full and low seems VERY small. Where's this third coolant tank? Thanks
  2. TimCom
    TimCom New Member
    san diego
  3. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    How did you determine what to research, do you have a OBD2 reader or known DTCs?
    That inverter pump should be running at all times. The liquid level is not that sensitive, but keep it between the lines and bleed.
    Do you have access to an OBD2 reader or can you visit the local auto parts store and borrow one?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    There are tons of things that can trigger those lights. I'm pretty sure that if they had a separate light for every possibility, there would be no room for people in the car. You'll need an OBDII reader that can read the proprietary Prius hybrid codes. Many, if not most, scanners at parts stores don't have that capability, but it's free, so worth a try. You'll need the code and the sub code to point you in the right direction.
    Raytheeagle likes this.
  5. TimCom
    TimCom New Member
    san diego
    Thanks for the replies, guys. I really appreciate it. I have to fix my wife's prius asap. I guessed at the inverter pump based on what I read here and other sites. I'm a mechanic, but I only work on Porsche 944's from the 1980's, so no OBDII. Funny that I help people online with 944 problems all the time, and NOW, I need the help. I'll get the codes somehow to verify the failure. Link me to a step by step how to on the pump replacement?
    Thanks again.
  6. TimCom
    TimCom New Member
    san diego
    Ok, OBDII scanner at oreilly's says: P0A80, P0441,P0445, P3000, C1310, C1378. I had to add a qt of oil as well. Just loosened the radiator cap and pink coolant came out so that seems topped off. If the inverter pump is directly behind the left headlight, It's vibrating, so it's pumping and the flow across the the top of the pink resv (top center of the engine) is moving fine.
  7. TimCom
    TimCom New Member
    san diego
    I'm told we need more detailed codes? Going to a toyota shop today. $50 to plug in and read the codes.
  8. bisco
    52,502
    How many miles on her?
  9. davecook89t
    davecook89t Senior Member
    1,093
    828
    Washington State, Florida
    How long have the lights been appearing? Assuming the 12V battery is not discharged, the P0A80 and P3000 do not bode well. You will still need the sub-codes from a Prius compatible reader to determine the exact source of the problem, but it looks like your HV battery either has corrosion or has modules that are failing. Fixing that will involve expensive parts, a lot of labor, or both.
    jerrymildred likes this.
  10. jerrymildred
    11,517
    14,158
    Tampa, FL
    P0A80 is a defective hybrid battery. There should be a sub code to tell you more specifically what's wrong with it. It may be a bad cell, but corrosion in the voltage sensing wires can give false reading.
    The 441 & 445 are in the evaporative system. Could be as simple as a loose gas cap. I just got a Prius, and now 2 error codes P0441 P0455... | PriusChat
    The 3000 I think is associated with the P0A80.
    davecook89t likes this.
  11. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    If the car is less than 10yrs/150K miles, you might have hit HV battery lotto. Ca is a CARB State.
    A dealer will need to confirm P0A80 themselves for warranty.
    If you are just outside of warranty (time/miles), ask for goodwill assistance. You are at the mercy of Toyota Customer service. Some people get lucky and get a significant chuck of the bill paid for, leaving them a relatively small amount left to pay (maybe <$1k).
  12. Patrick Wong
    18,210
    6,514
    The traction battery has failed, which is the meaning of P0A80. P0441 points to a problem with a fuel tank evaporative emissions leak, the vapor pressure sensor or the evaporative vacuum service valve.
    Regarding your question about whether the inverter coolant pump is working, you need to look at the coolant reservoir located between the engine and the inverter. I'm not sure if that is what you meant when you said "top center of the engine".
