Troubleshoot - Hybrid/Aux Battery Codes (P0A80/P3022)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jonathan St. Vincent, Jul 28, 2021.
  1. Jonathan St. Vincent
    Jonathan St. Vincent Junior Member
    Nashville, TN
    Typically I see myself as a fairly understanding DIYer, but this one has me uncertain... Happy to add more detail as available to help diagnose this. Thanks in advance!
    Backstory:
    Replaced complete hybrid pack with NewPriusBatteries on a 2007 w/ 60k-ish miles about 2 years ago due to original hybrid battery failure. Aux battery (TrueStart) replaced about 3.5 years ago by dealership (prior to purchase).​
    Situation:
    There are about 20k miles on the battery over the past 2 years. I have been intermittently popping code P0A80 for a few months; no block code was presented at that time.
    Initial diagnosis was to test the aux battery (false hybrid code positive), which showed a low charge. Aux battery was trickle charged for about a week (auto-stop charger), and went back up to decent "%" charge. Initial code went away for a week, then started popping again.
    Next decided to spend the hours to pull the hybrid battery and voltmeter the cells (to my back's chagrin). All cells tested normal, and I also cleaned a couple bus bars of corrosion. Codes went away again for two weeks, then came back...
    This time, I now have a P0A80 and (finally) a P3022 block code. However, I am still concerned if the aux battery might be the culprit.​
    Questions:
    • Do these symptoms clearly tell those with experience that it is for certain a bad cell, or possibly still the aux battery?
    • Is it worth taking to the dealership for the $150 diag? (If the aux, they should warranty the 84-month battery.)
    • Are there further diagnostics I can run (e.g. "duh, go get TechStream") or other recommendations?
    • Should I pursue a warranty cell from NPB?
    SFO likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Given the DTCs (OBD2 codes) reported (P0A80 and P3022), this would be the best course of action.
    Please report back in this thread.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    Having more data is very useful when determining the cause of a HV battery code. Using an app such as Dr Prius or Hybrid Assistant (android) with a compatible OBD2 bluetooth adapter (see DrPrius site) will let you view and log the block voltages as you drive the car.
    I would certainly contact NPB for info and next steps to take.
  4. PriusCamper
    PriusCamper Senior Member
    12,774
    5,175
    Pacific Northwest, USA
    This will be an interesting thread to follow... After a couple years of sales, NewPriusBatteries was bound to have a pack with problems. I wonder if this is a one time glitch or the first sign of trouble with this product? Hope the owner is able to help you replace this bad module.
  5. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Never too late to log in and offer an update (y)
    PriusCamper likes this.
