Troubleshooting Cruise Control Install on 2008
Discussion in 'Gen 2 Prius Technical Discussion' started by Jape056, Sep 10, 2019.
  1. Jape056
    Jape056 New Member
    St. Louis, MO
    Trying to install cruise control on my 2008 model. Read around a few forums and decided I needed to install a cruise control switch and a new brake stop light switch that is cruise control compatible. Purchased and installed the following aftermarket parts:
    • XtremeAmazing Cruise Control Switch 84632-08021 FOR Toyota Camry Corolla Matrix Prius Tundra
    • Beck Arnley 201-1566 Stop Light Switch
    Now my cruise control light will turn on and stay illuminated but will not activate when I try to set the speed. What issues could be causing my cruise control not to set?
    Possibly Helpful Troubleshooting Info:
    • I accidentally dropped the new brake light switch before install, but the brake lights still come on so I think the part is ok
    • Several climate control buttons on the steering wheel do not work
  2. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Probably a bad clock spring. It's the part that connects cables to the steering wheel.
    Skibob likes this.
  3. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    +1 if you’re already having trouble with some steering wheel switches, it’s likely to impact cruise-related switches too.
    Skibob likes this.
  4. Jape056
    Jape056 New Member
    St. Louis, MO
    Ended up being the cruise control switch itself. Was reading Amazon reviews and a couple reviewers noted that cruise would turn on, but wasn't able to be set. Bought a genuine Toyota 84632-08021 from the dealership parts counter and it worked perfectly.
    Thanks for the suggestions, I'll have to look into a potential clock spring issue
