TRS Morimoto Elite H11 HID kit issue
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 4rpr15, Sep 25, 2015.
  1. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    Sorry to hear. TRS has always taken care of me. I've bought hundreds of dollars of merchandise from them. Very rarely do I have a problem.
    I've never once installed a relay on any of my past vehicle. I go from experience. That's why I haven't installed relay.
    I have had the 2 ballast go out on me from TRS, but I've always been taken care of. One on my Subaru and one on my Prius.
    The one on my Prius was on for over 2 years.
    iPhone ?
  2. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    How much time passed before the ballasts went out? Did your headlights just shut off?
    MotoG3 ?
  3. A.Reyes
    270
    178
    Beaufort, 29902
    It was a little over 2 years or so. And I noticed they would flicker on and off and then stay on for a while then off for a while.
    Maybe it was because I've never used a relay, but I honestly don't know
    iPhone ?
  4. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    I was thinking about getting a kit from trs with the canbus. I contacted them (about a year ago) and they told me the reason they recommend the canbus relay is because there are no good + connection points under the hood. He said something about older versions of these cars having a post in the engine compartment and that it has been removed in the newer models.
  5. 4rpr15
    1,056
    375
    WI
    I believe the 5500k like what I have are rated 2500-3000 hours. That would mean the lifetime of owning the vehicle I would think in alot of cases.
    MotoG3 ?
  6. A.Reyes
    270
    178
    Beaufort, 29902
    I got the 5000ks. That was before they had the 5500k.
    TRS replace them for me because I was still under the warranty.
    iPhone ?
  7. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    I wonder if there is a noticeable reduction in light output if the HD Relay isn't used?
    iPhone 6+ ?
  8. 4rpr15
    1,056
    375
    WI
    Can anyone answer this I am also curious.
    MotoG3 ?
  9. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    nope, same brightness//
    4rpr15 likes this.
  10. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    No disrespect, but I assume you are answering that from experience of doing it both ways?
    Would there be a reduction in life expectancy of the bulbs or ballasts when not using the HD relay?
    iPhone 6+ ?
  11. 4rpr15
    1,056
    375
    WI
    I'm wondering the same.
    MotoG3 ?
  12. StarCaller
    1,284
    733
    yep, I had it first without to see if I would like it.
    after I drove at night I installed the harness the next day & it was the same brightness as without/
    the life expectancy I don't know, but I think if you always turn on your lights with the engine running (which is recommended neway), or like in the Prius in ready state, it shouldn't influence the longevity of the bulbs or ballasts/
    MPSchenck likes this.
  13. 4rpr15
    1,056
    375
    WI
    Do you mean that I should I wait until I hear the engine turn on after I press Start and put it in Drive or Reverse? Or is it safe to turn on the headlights right after pressing Start without hearing the engine turn on?
    MotoG3 ?
  14. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    As long as car in Ready mode, doesn't matter if engine is running or not.
    The auxiliary battery voltage is only 12.x volts, versus 14.4v or so when DC to DC inverter is online in Ready mode.
    I recommend using a dual relay HID harness vs a single relay harness. Or a single relay HID harness vs directly connecting HID ballasts to oem wiring harnesses.
  15. StarCaller
    1,284
    733
    once you see the ready sign, the electricity comes from the big battery, meaning that you will have hardly ne voltage fluctuations which could be a factor regarding the life time/
    so, as soon as you see the ready sign, you're on the safe side for switching the lights on/
    4rpr15 likes this.
  16. 4rpr15
    1,056
    375
    WI
    Above there have been some members who stated that they do not use any relay at all. Why do you recommend one in my case if the headlights work better without the relay? Now they turn on and stay on until I shut them off. With a relay it wasn't like that.
    MotoG3 ?
  17. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    Awesome! Thanks, man!
    I installed the HD Relay harness but couldn't get it as clean looking as I wanted it so I'm just gonna remove it.
  18. xliderider
    8,140
    3,280
    Honolulu, HI
    Because you were using a canbus relay or wiring harness, not the dual relay HID harness. There is a difference.
  19. Toppcat
    Toppcat Member
    223
    69
    Northern California
    not sure I have a fix ! Seems like it's random left then right not firing up! Tap a volt meter to the OEM harness to the canabus input to see if the system gets and sustain needed current! Seems like shutting it self down like my jetta once it detects a imbalance in the voltage and current draw! I maybe wrong ? Retrofit people recommended use 2 x capacitor on each headlight! It worked for the jetta!
  20. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    I took the HD Relay out tonight and at first there seemed to be an almost imperceptible flicker as the HID bulb was warming up, but honestly I think I might have imagined it. I watched the light on the garage wall very closely for such a long time that I saw after image for probably 10 minutes after I turned the lights off. If I notice the flicker any more I'll put the relay back on.
