TRS Morimoto XB LED bulb issue
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 4rpr15, Jul 24, 2015.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Has anyone tried these for their parking lights?' Mine start off yellow and turn white after a few minutes. TRS says this shouldn't be happening which I agree with. They are LED bulbs, not HID.
    T10 XB LED Headlight marker turn signal interior COB bulbs blinkers T10 194
    Here's a pic of the yellow parking lights on this pic. Why would LED's omit a yellow color like this?
    #1 4rpr15, Jul 24, 2015
    Dylan Doxey likes this.
  2. varun singh
    varun singh Member
    113
    Wayzata
    Any chance of taking photo from front with just parking lights on, I installed yellow bulbs, they are not sunnish yellow, but they do look good.
  3. 4rpr15
    1,056
    375
    WI
    It looks too yellow. I have never seen an LED light like this. Definitely going to get returned. I'm probably going to go with this one. I know someone who has ithis Philips LED and it looks great. I figure since I bought a TRS HD kit this LED would look good, but as you can see....far from it.
    Philips Blue Vision 194 T10 W5W LED Replacement Bulb
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    FYI, those rectangular lights above the cutoff in the picture posted against the garage door isn't from the parking lights. They're from the squirrel finder cutouts in the cutoff shields, which are inside the lowbeam projectors.
  5. 4rpr15
    1,056
    375
    WI
    So in other words is that pretty normal for my set up?
  6. varun singh
    varun singh Member
    113
    Wayzata
    It seems they are 3500k-4000K [off-white] color, at-least they appear so in the photo.
    My earlier 4300K bulbs looked same in color when paired with 55W ballast, I switched to 5000k, they look same as your's now.
  7. 4rpr15
    1,056
    375
    WI
    The TRS website shows this:
    TECHNICAL
    Rated Kelvin: 5000K
    Rated Lumens:175
    Input Voltage:12V-24V
  8. varun singh
    varun singh Member
    113
    Wayzata
    Looks like manufacturing defect or they sent you wrong the one [they did it first time for my order, I got 3000k HID bulbs, it took one week of argument to prove it :) 3000k with 55W was super yellow amplified].H ope yours is easy to exchange it.
    philips, sylvania [osram] or PIAA [slightly expensive]: all of these are reliable and would last atleast few years.
    I did bite the bullet and went with PIAA plasma ion yellow, actually doesn't look cheesy, kind of like classy yellow.
    Review: PIAA Plasma Ion Yellow 12v/5w 168 wedge bulbs | Balancing Act
  9. 4rpr15
    1,056
    375
    WI
    The manual says our lowbeams are H11 A 55W. TRS recommend that I get H11 B 35W 5500K with a Canbus relay. Why is that?
    I ended up ordering these for the parking lights. Heard great things about them. Otherwise I'm just afraid the lamp housing will fog up over time so I may just leave it with the OEM parking light.
    194 Philips LED Bulb | T10 Philips LED bulb | LED Wedge bulb | 2821 LED bulb
  10. varun singh
    varun singh Member
    113
    Wayzata
    At that time when i got, they had plain H11 and XB H 11 bulbs [double checked my order now], now I see that they H11 A and H11 B both in XB series, which is bit confusing to me,. my advice would be ask them again for Prius<model year>, if they say it incorrect, then exchange should be easy.
    Philips bulbs look good, Let me know the brightness of them, 15$ for a pair seems good deal.
    I have been looking at sylvani leds for license plates [10$ each buld :( ], ebay leds seems to be showing their age now.
    I just love the looks of PIAA,. maybe I will try them next.
    #10 varun singh, Aug 3, 2015
