True glide above 42 MPH Is it possible?
Discussion in 'Gen 2 Prius Technical Discussion' started by bestmapman, Feb 15, 2008.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    in my classic 01 prius , i can glide above 42 real easy, takes no effort to maintain, this is due to my overheating battery, plus outside temperature ( must be above 80 degrees)
    i average 54 mpg on highway driving
  2. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Where did PriusNomogram2.pdf come from? It looks to be for
    the Classic, given the 4500 max ICE RPM, and it totally misses
    heretical mode on the highway.
    _H*
  3. douglas001001
    douglas001001 smug doug
    222
    Chicago
    Instead of getting into reflashing, we know that if you are above 42 with the engine stopped and in neutral it will stay off, could you just issue the command for engine stop while in neutral above 42 and the engine idling? Could can-view be programmed to do this?
  4. Bob64
    1,540
    93
    Virginia
    From what my understanding of canview is: it's basically like a scangauge. It talks with ECU and other computers.
    So lets say a "CAN" engine stop command existed. Even if we were able to send it and have the engine ECU obey, the other computers would probably immediately send a "Holy shit, the engine is off, the MG1 is reaching the red rev limit, start the engine NOW!" message to the ECU of the engine.
  5. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    That may be the way to do it. Does anyone know if this is possible.
  6. Kaos1
    Kaos1 Junior Member
    Mid-Alantic
    Has anyone experienced damage to the MG1 due to "overrevving" while coasting in neutral?
    Kaos1
  7. sweetguy
    sweetguy Junior Member
    85
    Maine
    Do you all realize that the manual says: " do not, under any circumstances, shif the lever to N while the vehicle is moving -- doing so can cause significant damage to the transmission..." page 124 of 2998 maunual.
    My question is: what is N for? When would one use it?
  8. sweetguy
    85
    Maine
    Sorry for the typos,
    I meant to say:
    Do you all realize that the manual says: " do not, under any circumstances, shift the lever to N while the vehicle is moving -- doing so can cause significant damage to the transmission..." page 124 of 2008 maunual.
  9. bwilson4web
    16,544
    We have speculated about this in Prius_Technical_Stuff and the two leading hypothesis are:
    • mechanical stress - flies apart
    • electrical stress - over voltages destroyes inverter assembly
    However, I don't know of anyone who has performed the 'forbidden experiment.'
