TrueStart OEM 12V Battery Warranty
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kayceee, Jan 22, 2020.
  1. kayceee
    kayceee Junior Member
    Los Angeles
    Hi All,
    Just wanted to provide a data point here.
    Went to Toyota in Marina Del Rey (Los Angeles) to inquire about a TrueStart 12V battery for my 2012 Prius III and was told by parts/service that while most TrueStart batteries have a 84 month warranty (2 year free replacement then prorated), the Prius TrueStart battery has a different warranty of 1 year free replacement then 2 years prorated at 50%.
    Can anyone else confirm this information?
    Was looking to get another OEM since my first one lasted for almost 8 years, but with such a limited warranty I'm leaning towards getting another battery with at least 3 year free replacement.
    Thanks.
    51,501
    i understood that the prius true start had the 84 month. did you ask for documentation?
  3. StarCaller
    StarCaller Senior Member
    1,274
    726
    Cedar Crest, NM, USA
  4. kayceee
    Los Angeles
    In true dealership fashion, nobody had documentation - the parts guy just asked the most experienced service guy. I may go to a different dealership to see if they have documentation.
  5. StarCaller
    1,274
    726
  6. kayceee
    Los Angeles
    Thank you StarCaller
    Does that battery work for your 2014 Prius? This is the only battery that shows up when I search for my 2012.
  7. bisco
    51,501
    all gen 3 batteries are the same
    elementnomore likes this.
  8. kayceee
    Los Angeles
    Got it, so the more expensive one I posted is no better than the cheaper battery StarCaller posted?
  9. bisco
    51,501
    different dealerships have different prices. what matters is the model and fitment.
    i went to germain toyota and plugged in your car. it said $200., thats what i paid as well.
  10. Elektroingenieur
    2,515
    3,281
    Three Touring
    Toyota dealers in the U.S. have, over the years, had two sources of auxiliary (12 volt) batteries. There are original equipment (OE) batteries, stocked by Toyota parts distribution centers, and TrueStart batteries, stocked by Interstate Batteries distributors. The dealer or customer doesn’t usually get to choose: for any particular size and application, the OE battery is typically discontinued once a TrueStart battery is available.
    According to Policy 4.11, Service Part Battery Warranty Coverage, in the Toyota Warranty Policy and Procedures Manual (available by subscription to techinfo.toyota.com), all TrueStart batteries—for hybrid vehicles or otherwise—have the 24-month replacement/84-month prorated warranty. OE batteries for hybrid vehicles—assuming you could still get one—have a 12-month, non-prorated warranty. Either way, any remaining New Vehicle Limited Warranty coverage also applies.
  11. kayceee
    Los Angeles
    Two Toyota
    Thank you for this information! Do you know if the same 84 month prorated warranty holds if you self-install vs getting installed at Toyota service center? I have read some user posts that buying the battery over the counter changed their warranty period.
    Elektroingenieur likes this.
  12. Elektroingenieur
    2,515
    3,281
    Three Touring
    You’re most welcome.
    Yes, it does; the policy applies to any “Toyota Genuine replacement battery installed by a Toyota dealer in a Toyota vehicle or purchased over-the-counter.”
    Ni-MH or Li-ion high-voltage (HV) batteries are the exception; these are warranted for 36 months if installed by a dealer in a vehicle that isn’t a commercial, fleet, or livery vehicle, or for 12 months, otherwise.
    diplomatic and kayceee like this.
  13. Mendel Leisk
    40,939
    I depend on CTEK, simpler than the warranty run-around.
  14. Tnx
    Tnx Junior Member
    Claremont, CA
    Sorry to res this thread. If I'm understanding correctly, the battery for around $150~, model number 00544H4052470 is for the Prius TWO correct? The toyota website doesn't say anything about it fitting my Prius 3 2011. Meanwhile, searching for the other battery model 2880021171 linked in post 7 by Kaycee shows them out of stock everywhere around me in SoCal LA area.
    Is this just a supply chain issue or are they discontinuing these batteries as well? Seems like the only other choice for a new battery for me is the yellow top or AC delco ACDB24R on Amazon.
  15. Mendel Leisk
    40,939
    Try local automotive retailers selling batteries: they invariably have a website that'll let you enter your vehicle stats, show what they have that's compatible.
    I'd much rather deal local with batteries, in case there's any hiccups.
    I believe all the 3rd gens are the same battery. Going through the exercise, I see the Canadian Tire Store about 10 kms east of me have 3 of their compatible AGM Motomaster battery in stock now:
    I believe the above's pretty much physically identical to the OEM Yuasa, and same spec's.
    #15 Mendel Leisk, May 11, 2020
    diplomatic likes this.
  16. Tnx
    Tnx Junior Member
    Claremont, CA
    All the stores around me either only have yellow tops, or have a store branded battery that runs about 225. At that point it seems like I should just buy the OEM one from toyota for that crazy warranty no? I have three toyota dealers within 12 miles of me, which seems local enough, but none of them are open.
  17. Mendel Leisk
    40,939
    You were saying the OEM were out-of-stock? Maybe just on Amazon, but dealership still has them?
    $225 USD is pretty steep, I mean I'm seeing same price up here in CDN.
    #17 Mendel Leisk, May 11, 2020
  18. Tnx
    Tnx Junior Member
    Claremont, CA
    Yeah I meant the OEM is out of stock at all the dealerships around me. I don't see Amazon selling any of the OEM Truestarts. And yeah $225 is steep but I don't see too many options, besides the $160 AC Delco. I guess I should look into that one and see what others say about it.
  19. Mendel Leisk
    40,939
    I think there's not that many manufacturers, you can count them on one hand, just a lot of different badging.
  20. Peter123
    Peter123 Active Member
    131
    128
    I think the current Toyota part number for a gen 3 12 volt battery is 00544-21171-325.
    pjksr02 and Mendel Leisk like this.
