Trunk closing problem
Discussion in 'Gen 3 Prius Main Forum' started by Paulioats, Jan 6, 2019.
  1. Paulioats
    Paulioats New Member
    VA
    My trunk, once its closed, open door warning on dashboard will stay on, and the car wont recognize that the trunk is closed, but it’s closed the way it should be. I’m thinking its either problem with the latch or the hook, but cant quite figure out whats wrong. Please help!
  2. Mendel Leisk
    42,349
    52,857
    it's a double lock, so can be hooked but not closed all the way. try pushing on it while someone is sitting in the drivers seat.
    make sure there is nothing interfering with the latch
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    Bisco is correct. It can seem like it’s closed but sometime it can fool you. The hatch needs to be moderately assisted so that the secondary, main latch is tripped.
  5. grantb3
    grantb3 Junior Member
    60
    Orange County, CA
    I had a problem with the rubber trim and that prevented that last mm of closure or whatever is required. I just pushed the rubber trim back in (the problem was obvious once spotted) and it was OK.
  6. Robert Bushinski
    Robert Bushinski New Member
    mn
    This is how I fixed our 2012 Prius V latch problem. Trunk would not close. Second latch would not turn the light off on the dash. Weather stripping seemed swollen or hard and there is no adjustment on the latch for it. I popped out the plastic handle for lowering the trunk lid and looked inside. I took out the four fasteners that hold the latch mechanism. I pushed the latch mechanism back and used my dremmel tool to elongate the screw holes towards the ground so the mechanism would not hold the door so tight. Lid now closes properly.
