Trunk Issues - Latch & Trim
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hybrid Hobo, Dec 2, 2025.
  1. Hybrid Hobo
    Hybrid Hobo Member
    217
    55
    New Jersey
    My trunk has been having issues for quite a while. But it's worked most of the time with some finessing.
    The problem is that the latch that you press to open the trunk gate is all gummed up. It literally feels like a hunk of semi-wet bubble gum when I press it. Further...
    It is quite often that the trunk will not open on the first attempt. I have to keep pressing/pulling to get it to work.
    I walked out to my car this morning and went through just this routine, when I heard the trim piece crack from using too much pressure. It's still on (not hanging or anything), but it's very loose. And I'm not going to risk opening the trunk in case it falls off completely.
    I'm not concerned about the trim piece, because they sell knockoffs online, which I know because my buddy's trim piece on his Gen 2 broke, and I ordered one for him. I'll get one of those. However...
    My main question is, in addition to that trim piece...should I JUST order the latch (small black piece with wiring) itself, or do you think I'd need the whole lock actuator?
    Thanks.
  2. Hayslayer
    Hayslayer Active Member
    539
    331
    They also sell kits to just replace the rubber cover for 10-15 bucks. This is a very common problem. It's best to remove the button from the garnish trim piece, then the old gummy stuf can be removed pretty easily with a small pick or knife, and cleaned up with a rag or toothbrush with carb cleaner. Then just install the new rubber cover and presto...just like new.
    I've also seen many that just have the old gummy stuff removed and never had a replacement rubber cover installed. Buttons still worked perfectly fine.
