Trunk lid leak after rain
Discussion in 'Gen 3 Prius Main Forum' started by robertus, Sep 8, 2021.
  1. robertus
    robertus New Member
    Maryland
    Hi Gang
    Hoping someone's had some experience with this. The short version is that, after any significant rainfall, water appears to be accumulating in the trunk lid above the rear window. When I drive the car or open the hatch, water runs out of the top part of the trunk, above the passenger seat. Rest of the car is dry, and it doesn't appear to be spilling out when the trunk is closed.
    I just had the car in the shop for the 80K maintenance, they ran a check and said all the drainage channels were clear - however, when I picked the car up, I opened the trunk and, surprise surprise, a bit of water leaked out of the same spot.
    This vid's from after the last big rainfall:
    Any idea what might be going on here?
    Thanks!
  2. burrito
    burrito Active Member
    274
    114
    If I remember correctly, there is weatherstripping on the outside of the car between the panels which can wear out. So the water may be getting in between the roof and side, then making its way to where you eventually find it.
    robertus likes this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    A reputable glass shop might be your best bet. If I had to guess, I would say that the glass perimeter seal is leaking. That, or the rear wiper shaft seal is leaking. That’s about the only way water can get into the hatch area.
    Has the car had the glass replaced for some reason?
  4. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    Check the seal around the wiper arm. It's probably cracked.
    It's inexpensive and easy to replace.
    If that's not the problem, then the seal around the rear glass my be cracked
    If that is the case, you could run a bead of black silicone around the glass and deck.
  5. tellyourdogisaidhi
    tellyourdogisaidhi Junior Member
    Bethlehem, Pennsylvania
    Permatex makes a flowable silicone that worked well for me around the hatch hinges. Part # 81730
    StevenM likes this.
  6. ASRDogman
    8,063
    4,086
    Any update? Have you found the leak?
  7. framistat
    framistat Junior Member
    43
    Fairport, NY
    On my 2015, during the winter I had knocked the rear wiper washer spray nozzle out of its hole when brushing off snow. This let water into the lid and a waterfall into the interior when the lid was opened as you describe. Reinserted it, no more water.
    StevenM likes this.
  8. 462disco
    462disco Junior Member
    34
    17
    Socal
    Bump for relevant info.
    I had the exact same issue in the first video posted on a 2013 I just bought - water leaking down after a rain on the left side trunk trim. My issue was the rear wiper grommet.
    Fix -
    I pulled my trunk trim using this video
    You can see the residue around the gasket and corrosion on the motor in the pictures below.
    Part you need is 85143-72010, Grommet, Rear Wiper Motor. Pop the cap off the rear wiper, it's one nut you remove and you can access the gasket.
    Hope this helps someone in the future.
    don K otay and bisco like this.
