Trunk
Discussion in 'Gen 2 Prius Main Forum' started by Cheap!, Oct 12, 2006.
  1. harper42
    harper42 Member
    226
    <div class='quotetop'>QUOTE(BrianTheDog @ Oct 15 2006, 01:03 PM) [snapback]333081[/snapback]</div>
    mmmmm.... yes. all the drawers and storage areas. Handles and glove compartment shelves, folding hatch floor support, all the usual. Just wondering if I've missed something really unique.
  2. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(dulcimer @ Oct 15 2006, 03:38 PM) [snapback]333073[/snapback]</div>
    One thing that was bugging me was that the hatch cover (tonneau cover whatever that is) had a tendency to flop up and partially block the rear view unless I had it closed (by closed I mean pulled across the trunk). I tried rotating the cover assembly so that the side it retracts into would be out the side instead of the top, but the whole thing is shaped to fit in the right way only. I finally figured out that if you pull the rounded flap down, so it hangs down by its own weight, it won't flop up on its own. Of course you could keep it closed which would also keep it from getting in the way.
    By the way, I discovered the trunk floor hold-up rod when I was showing off my new car to some co-workers. We all found something new that day! I just wish the plastic trunk bin had some wire rod reinforcement around the rim because it bends easily if you lift it out with heavy items in it.
    P.S. By pulling the down the rounded flap, I mean pulling it out a little then positioning the flap so it points straight down, with the little tabs on the flap resting on the underneath of the retracting mechanism. This seems to work well enough.
  3. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Oct 15 2006, 01:48 PM) [snapback]333022[/snapback]</div>
    That's not so. Here's 4 Toyota dealers readily available on ebay selling cargo nets
    http://cgi.ebay.com/ebaymotors/Toyota-Priu...sspagenameZWDVW
    http://cgi.ebay.com/ebaymotors/Genuine-Toy...sspagenameZWD1V
    http://cgi.ebay.com/ebaymotors/NEW-OEM-CAR...sspagenameZWD1V
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(BobZ @ Oct 15 2006, 03:58 PM) [snapback]333134[/snapback]</div>
    Here is a link to the Toyota Prius Accessories web page featuring the cargo net:
    Accessories: 2007 Prius
  5. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(BobZ @ Oct 15 2006, 06:58 PM) [snapback]333134[/snapback]</div>
    I'm confused. He said it's sold by Toyota dealers, you say no, it's sold by Toyota dealers. What am I missing here (besides being cheaper through ebay)?
  6. BobZ
    BobZ New Member
    323
    Long Island, NY
    I thought he said not sold by many dealer sorry my mistake
  7. IsrAmeriPrius
    4,333
    Southern California
    I never wrote that it is not sold by Toyota dealers.
    This is what I wrote:
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Oct 15 2006, 10:48 AM) [snapback]333022[/snapback]</div>
  8. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Oct 15 2006, 07:33 PM) [snapback]333160[/snapback]</div>
    A thousand pardons.... :D
    I
  9. IsrAmeriPrius
    4,333
    Southern California
    It would appear as if BobZ edited his post (#26) after I posted my reply (#27).
  10. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Oct 15 2006, 07:55 PM) [snapback]333168[/snapback]</div>
    and your point..........
  11. Tideland Prius
    16,668
    <div class='quotetop'>QUOTE(PA @ Oct 15 2006, 03:51 PM) [snapback]333128[/snapback]</div>
    Kinda funny. I was at a dealership and they had it in the way you wanted it. I know it doesn't fit cause I tried it but they've managed and I'm pretty sure they're scratched or busted something because I could not remove that tonneau cover. They forced it in pretty well.
  12. Cheap!
    Cheap! New Member
    1,157
  13. Tideland Prius
    16,668
    <div class='quotetop'>QUOTE(Cheap! @ Oct 15 2006, 08:28 PM) [snapback]333270[/snapback]</div>
    Indeed it does. Toyota has thought of everything.
  14. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    <div class='quotetop'>QUOTE(Cheap! @ Oct 15 2006, 09:28 PM) [snapback]333270[/snapback]</div>
    Wait, there's a storage space for that cover? I've always thought it was annoying that I had no good place to put that thing when the seats were folded down. What do you mean by "under the floor board in the truck"?   :huh:
  15. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    Lift up the cargo area cover (in the "trunk") which is under the cargo mat. You will probably need to "unlock" it by twisting the two round locking mechanisms that will be close to you. When you lift the cover, you'll see a couple of places on the right and left side of the storage tray that are the same shape/depth as the tonneau cover case. The storage tray is not as wide as the tonneau cover, so you will need to slide the tonneau cover into the left side until the right side will drop in. This is in your owner's manual, so if I have not described it well, the manual will have an illustration.
  16. darelldd
    6,059
    389
    Northern CA
    I don't store mine down there (or use it over cargo for that matter) because it just gets in my way. I use my dark tint for privacy back there! My cargo cover sits in the garage wrapped in plastic awaiting resale time.
    When in the storage position, it blocks easy access to anything that's in the bin (assuming you have the floor in still... and crap on top of it like it seems I always have!)
  17. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    I should note that everything mentioned in this thread is covered in the Owner's Manual (at least the 2004 version) in the Other Equipment section. Once you are comfortable with the car, it's a good idea to peruse the full manual to discover these things.
    Here's a tip that's not there:
    If you have trouble closing the hatch without pushing the spoiler at some point, try pushing against the Toyota emblem in the center. The leverage is suprisingly good there, and you don't feel like you might accidentally break something.
  18. Tideland Prius
    16,668
    <div class='quotetop'>QUOTE(kinghuang @ Oct 15 2006, 08:59 PM) [snapback]333287[/snapback]</div>
    lol. Well, that's the 2nd thing you learned this past week.
  19. RBW111
    RBW111 New Member
    139
    El Dorado, AR
    I guess everyone knows you cargo cover will fit in the "trunk".
  20. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(Cheap! @ Oct 12 2006, 02:08 PM) [snapback]331850[/snapback]</div>
    Very useful information. Only today I had to carry a load of leaking flower pots containing potted plants. Remembered this post. The plastic well was exactly right for this load. I would not have otherwise thought of it.
    Grateful Priuschatter!
