Trying Not to Lust After the Prime
Discussion in 'Gen 4 Prius Main Forum' started by goinskiing, May 15, 2018.
  1. Tideland Prius
    16,677
    Good luck!
    alanclarkeau likes this.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Go go go!
    I bet you’ll be very pleased with it.
    goinskiing likes this.
  3. goinskiing
    goinskiing Active Member
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    Just got it!!!
    One silly question. I notice the car turns off in park while charging after 2 or 3 minutes, is there a way to change that?
    iPhone ?
    eustachio and Tideland Prius like this.
  4. mr88cet
    2,313
    1,335
    Austin, TX
    Yeehah! Congrats!
    I don’t follow the situation you’re describing there. Can you expound upon it, or just rephrase it?
  5. goinskiing
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    Yeah, I had the car plugged in and turned off, and then came back out an hour later to show my son the car. I turned the car on to show him some of the features, after about 2-3 minutes the car turned itself off (as if I had pressed the on\off button).
  6. krmcg
    2,592
    2,393
    Whittier, CA
    Are you sure it was "ON" and not in accessory mode? It will turn off from accessory mode to save battery life.
  7. goinskiing
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    Lol, it probably was, especially since the AC was running. Still have more to learn on this thing.
    iPhone ?
    RCO and krmcg like this.
  8. mr88cet
    2,313
    1,335
    Austin, TX
    I’m not immediately sure whether this matters, but was it still plugged in at the time?
  9. goinskiing
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    Yeah, time to hit the manual lol.
    krmcg likes this.
  10. mr88cet
    2,313
    1,335
    Austin, TX
    I’d expect that, if you charge it up, drive it, charge it up again, drive it, etc., it will behave pretty intuitively for the most part. There might be some less-intuitive behavior when you’re in the car as it’s charging.
    RCO likes this.
  11. goinskiing
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    So apparently when it’s plugged in it will not be in READY mode for obvious reasons hence it will power off after a short while.
    iPhone ?
  12. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    The AC compressor only runs in READY mode (the mode where if you press the accelerator pedal you will go somewhere). In ON mode only the fan will run, not the compressor. In ACC mode you pretty much have only radio and 12V outlet.
    Based on your description you were probably in ON mode and just the fan was running. Per the manual the car should stay in ON mode for one hour before shutting off (20 minutes in ACC mode). Although I seem to remember some people reporting early on that the Prime shut off much earlier than the designated time. But I don't think it was 2-3 minutes. Maybe after turning it on you opened and closed the driver door for some reason? I think that might cause it to shut off within a few minutes if you do that and don't start the car.
    Then again, in your understandable excitement of showing off your new car, unless you had a dash cam pointed at you there is no telling what you did :)
    The first part for sure, it won't go into READY mode if the charge cable is connected, even if you aren't currently charging. And if it you connect the charge cable while in READY mode it will shut off the hybrid system.
    As for ON mode turning off after a few minutes instead of an hour when you are charging, that's possible although I didn't see anything about that in the manual. But not everything gets documented.
    #132 Since2002, Jun 23, 2018
    RCO likes this.
  13. goinskiing
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    Hahaha, most likely the case. I guess I should mosey on over to the Prime forums now eh?
    iPhone ?
  14. Tideland Prius
    16,677
